02-06-2020, 12:58 PM | #1 |
4528
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
Exact weights of Brembo calipers 340 & 370?
Curious if anyone has the EXACT weights of the front Brembo 4-piston calipers in 340 and 370 sizes? They use the exact same pistons, pads, pins and clip so the only difference in weight should be from the 15mm extended casting.
I don't think the weight difference is significant but don't want to ignore it if the information happens to be available. Just playing around with some unsprung weight calculations. Thanks! |
02-09-2020, 08:13 PM | #2 |
993
Rep 1,934
How can they affect unsprung weight if it's fixed to the upright? Only the rotor would.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
02-09-2020, 09:00 PM | #3 | |
4528
Rep 5,392
So it's everything riding on top of the springs that is considered "sprung" weight. So that would mean anything that is riding on that top spring mount where it bolts to the body. |
Logicoeur992.50 |
02-09-2020, 09:55 PM | #5 | ||
10
Rep 35
johnung4528.00 |
02-10-2020, 04:41 AM | #8 |
4528
Rep 5,392
This thread kinda went off on an unintended tangent as I was comparing weights of various brake rotors and just got curious about the weights of the 340 and 370/380 calipers.
02-10-2020, 12:15 PM | #9 | |
1599
Rep 3,748
Anyway, just a comparison I did a front brake upgrade on my S14 Silvia to a Brembo GT 4 piston good for 13.5" rotors... they weight 11 lbs. Its probably close to that. |
02-10-2020, 01:02 PM | #10 | ||
4528
Rep 5,392
I looked into the BremboGT kits but wouldn't fit under my stock 18" wheels. Wanted to keep stealth look and not spend money on wheels. Then I found the StopTech full floating in 370x30 stock size. Worked out perfectly! |
02-10-2020, 01:26 PM | #12 | |
4528
Rep 5,392
02-10-2020, 01:30 PM | #13 | ||
4528
Rep 5,392
02-10-2020, 06:17 PM | #14 |
993
Rep 1,934
Really wish stoptech made those in 340mm as well. Only option we have is ECS
02-11-2020, 03:51 AM | #16 |
4528
Rep 5,392
The StopTech 370mm x 30mm were about a 5-6 week wait special order. I really like them because they are very similar to the rotors that the BremboGT brake kits use. Those GT calipers & rotors are very different in size (less diameter but thicker) and very expensive- meant for racing. (Tracking would use the slotted rotors)
02-11-2020, 03:58 AM | #17 |
4528
Rep 5,392
Yes, StopTech makes the two-piece drilled fixed (rather than floating) rotors. They are excellent! I have them in the 345mm x 24mm size for the rear. See photo.
02-11-2020, 04:07 AM | #18 | |
4528
Rep 5,392
02-11-2020, 04:45 AM | #19 | |
6420
Rep 8,500
Sprung mass is the rest of the vehicle (in simple terms).
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
02-11-2020, 04:46 AM | #20 | |
6420
Rep 8,500
johnung4528.00 |
