02-06-2020, 10:47 AM | #1 |
235
Rep 228
Drives: 2022 G20 330E
f3x HU MOST connection
Hello, does anyone know is there any HU that does not have MOST connection in f3x models?
02-06-2020, 11:10 AM | #3 |
235
Rep 228
02-06-2020, 05:39 PM | #4 |
588
Rep 2,302
Unfortunately, that's not easy to say.
As far as I know there are simply radios with and without MOST. The safest way would be to remove the radio and look at the back. If a Combox is installed in the trunk, the MOST can be found there. |
02-08-2020, 06:38 AM | #5 |
12
Rep 56
If your customer has BKombi and want to retrofit 6WA, then he need also a MOST cable.
He has to remove the radio and look at the back as aztebmw said. There are 3 possibilities: 1. A MOST cable is connected to the radio -> a Y MOST cable is needed to add 6WA to MOST ring 2. No MOST cable is connected, but the radio has a free MOST socket -> a simple MOST cable is needed to connect radio and kombi 3. Radio has no MOST socket -> 6WA retrofit not possible w/o HU retrofit. |
02-09-2020, 03:52 PM | #6 | |
235
Rep 228
https://www.ebay.co.uk/itm/143516151393 |
