Bimmerpost
4 Series
Technical Topics Wheels and Tires Rim Protectors
      02-05-2020, 05:42 PM   #1
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Rim Protectors
Hi,
I hate to say it, but with the cr***y weather of late, we have gotten rim rash on 2 wheels of 20 M340 with 791M wheels.
I know, I know should be careful & use side view mirrors, BUT as the saying goes, "Kaka occurs!"
In that case does anyone have any recommendations on some good rim protectors?
Thanks
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH|
Retired: 2014 328i
BMW CCA
      04-28-2020, 04:03 PM   #2
hottroc
45
Drives: BMW 330e
Did you find any?
I did the same on one of mine. Never done it on a car before. I think the wheel/tyre combination coming from the factory is one where the tyre is not proud of the wheel enough to protect it, or maybe because the tyres are such a low profile brings the wheel down low enough to catch the curb. Or both those things.
      04-29-2020, 07:05 AM   #3
jstnstr
jstnstr's Avatar
Drives: G20 M340xi
Did you just censor the word "crappy"?
| M-Performance Exhaust | JB4 Map 4 on E35 | BMC Red Panel Filter |
| Previous: 18 M3 ZCP | 17 M3 6MT | 15 M235i |
      04-29-2020, 08:44 AM   #4
RSnic
RSnic's Avatar
@hottroc ,
Unfortunately, I haven't
I checked with Rim Blades, but as they told me they won't work on my wheels because of the small gaps in rim where spokes connect (M791 wheels).
Since I had a bad experience with my F30 with rim Protectors (bought from a reputable place, followed installation guidelines, let cure, but came off in a week or less), I've been cautious. I used extra fine wheel on my Dremel tool & 1500 sandpaper to buff out dings (see my post on another thread) & had them re-created with ceramic
Having said that, am still looking for rim Protectors
Al
Retired: 2014 328i
BMW CCA
      04-30-2020, 05:40 AM   #5
hottroc
45
Drives: BMW 330e
I believe I have the same wheels as you. They are lovely wheels.
I've sanded out my rash but it has left the allloy area concerned a little dull. I could just coat with polish and/or ceramic but I was wondering if the wheels initially had a top-coat of clear lacquer? If so I'd do that first.
If you do manage to find rim-protectors drop me a PM as I too can see this happening again. The wheels are low-profile so line up with the curb and the tyres not fat enough to protect. I have the run-flats, maybe that's why there's no bulge in the tyre like a normal tyre.
      04-30-2020, 06:45 AM   #6
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
United Kingdom
443
Drives: BMW G20 330i RWD M Sport
Yes they are coated with clear lacquer
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      04-30-2020, 06:53 AM   #7
hottroc
45
Drives: BMW 330e
Thanks.
So my plan is to polish with Brasso, then apply a top coat or two (I have a touch up stick of clear lacquer rather than spray but think it will do), then a coat of proper polish (and ceramic eventually).
Does that sound right?
      04-30-2020, 09:30 AM   #8
Tam the Bam
Grumpy Old Git
United Kingdom
443
Thanks.
Sounds right although I would make sure you get any oil residue off after using brasso and before you apply the clear lacquer.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      04-30-2020, 09:54 AM   #9
hottroc
45
Drives: BMW 330e
Ok, so something like isopropyl alcohol to do that?
      04-30-2020, 10:01 AM   #10
Tam the Bam
Grumpy Old Git
United Kingdom
443
Yes, that would do it.
Before you do it use as fine a wet and dry sandpaper you can get 2500 or greater will help give it a really smooth surface and better shine of the dull surface.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      04-30-2020, 10:14 AM   #11
RSnic
RSnic's Avatar
hottroc ,
I agree with @Tam the Bam! After using my Dremel tool with 400 grit wheel, I then used 1500 & finally 3000 grit sandpaper. You can then use something like Brasso and wipe with Isoprpyl Alcohol (at least 71%) before clear coating.
Will do on sending you PM if I find Rim Protectros; please do the same
Thanks
Al
Retired: 2014 328i
BMW CCA
      04-30-2020, 12:03 PM   #12
hottroc
45
Drives: BMW 330e
Thanks guys. 1500 grade is the finest I've got at the moment but I'll see if I can get out to Halfrauds to get some 3000.
Another query, are all clear lacquers the same? Think the one I have is a Nissan one, presume it will do?
      04-30-2020, 12:35 PM   #13
Tam the Bam
Grumpy Old Git
United Kingdom
443
Don’t see why not.... try it on something first?
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      04-30-2020, 06:06 PM   #14
Burrcold
5210
Drives: 2024 M3 Comp xDrive
What's a rim protector?
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5
      05-01-2020, 04:02 AM   #15
Tam the Bam
Grumpy Old Git
United Kingdom
443
See here
https://www.chipsaway.co.uk/blog/wha...-do-they-work/
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
Burrcold5210.00
      05-01-2020, 04:48 AM   #16
hottroc
45
Drives: BMW 330e
Hmm, don't think Halfords sell 3000 grade, might have to search on ebay.
      05-01-2020, 05:48 AM   #17
Tam the Bam
Grumpy Old Git
United Kingdom
443
I got a pack of different grades on eBay.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      05-07-2020, 10:30 AM   #18
hottroc
45
Drives: BMW 330e
Having looked at the wheels again, they are not ultra-shiny like chrome, it's more of a slightly brushed effect. So I'm thinking the higher grade sandpapers might not be a good idea.
Any tips on how to get that effect? They are totally smooth but looks more like a semi-polished aluminium, I'm wondering if it should be left a little rougher then smoothed with the top coat?
      05-07-2020, 10:38 AM   #19
Tam the Bam
Grumpy Old Git
United Kingdom
443
Try a 1500 and keep sanding the same way so the fine scratches left by the wet and dry all go the same way. i.e. the same direction as the rest of the wheel. If that leaves too many scratches then use finer grade to make it look like the rest. If not enough come down to 1200 etc.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      05-07-2020, 10:45 AM   #20
hottroc
45
Drives: BMW 330e
Thanks for your advice, I'll have to try with a different grade.
The rim looks finer than the spokes. I was only supposed to be repairing the rim but caught a couple of spokes a few times with the sandpaper which has taken the shine off. The brushed effect is more prominent on the spokes but I don't want to risk sanding them much more, I'll end up having to do the whole wheel, then the other 3 to match lol.
      05-07-2020, 11:24 AM   #21
Tam the Bam
Grumpy Old Git
United Kingdom
443
I practiced on an old stainless steel kettle I had to see how the different grades made it look......
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
RSnic657.50
Search this Thread:
Advanced Search
g20
