02-03-2020, 08:06 AM | #1 |
Rep 51
Drives: BMW 530 xdrive
pb rear fog lights
Hello, I programmed that my rear fog lights come on at the same time as the stop lights, it works ....
on the other hand, I can no longer turn on the fog lights via the control at the front ... the warning light comes on on the dashboard but not the lights ... where is my error? or my errors?or tell me what parameters to check? if necessary you give me the basic parameters and we start again together ... Thanks for your help... cordially i'm sorry, i'm french...:RÉ Last edited by music21050; 02-03-2020 at 08:11 AM.. |
02-04-2020, 04:48 PM | #2 |
Rep 51
after testing, I found my error, I have part of the answer ...
here is my coding: REM> MAPPING_NEBELSCHLUSSL_L_FUNCTION> 0E (rear light with inter) at 0C REM> MAPPING_NEBELSCHLUSSL_L_OUTPUT> 00 to 1C (the left rear fog is 1C, the right is 1D) REM> MAPPING_NEBELSCHLUSSL_L_PWM1> 87 to 64 REM> MAPPING_NEBELSCHLUSSL_R_FUNCTION> 0E (rear light with inter) at 0C REM> MAPPING_NEBELSCHLUSSL_R_OUTPUT> 00 to 1D REM> MAPPING_NEBELSCHLUSSL_R_PWM1> 87 to 64 OE = Inter (nebelschlusslicht) OC = Order with stop but no more inter possible 01 = always on now a question: is there a value that would combine OE and OC? :arc: in advance thank you for your help .. Last edited by music21050; 02-04-2020 at 04:54 PM.. |
