Speaker upgrades on an e90
02-02-2020, 04:50 AM | #1 |
Rep 5
So, sorry if this has been covered a thousand times but IÂ’ve read so many threads thereÂ’s too much info aha.
So IÂ’ve got an 06 e90 320d saloon, IÂ’ve read about different sound systems hifi etc and I have no idea what I have. The cars about to hit 200k and the passenger side door speaker has just started farting, I was just going to replace the two door speakers for some better ones, but then I started down the rabbit hole of alpine/blaupunkt/L7 and now it might be worth getting a kit of all of it at once Is it worth getting the whole kit with subs and amps? Are the standard subs any better when used with an amp? Thanks to this forum IÂ’ve found out about putting tweeters in, is the wiring in the door already for those? IÂ’m used to fiddling with systems, but on old cars with aftermarket head units, IÂ’m a bit mused when it comes to the more modern stuff like this. Any help would be awesome. |
02-03-2020, 04:27 AM | #3 |
Rep 5
Cheers for the info!
So mine is the base system, no tweeters no centre speaker in the dash. What would make it sound worse with new speakers? Was looking at a set of tweeters and door speakers and buying the new plastic with the holder for the tweeters I value my car but it’s done a lot of miles so I don’t really want to spend to much on it because you never know when it’ll die aha Fine with diy, was a mechanic for a good number of years, not too sound system literate but I can wire stuff and take stuff apart easily |
02-03-2020, 10:23 AM | #4 |
1911
Rep 13,104
The doors on these are pretty easy and the floor not
to bad for access. If you read the links I provided the specifics of how to modify the base system are layed out in detail. Read the last link . Last edited by ctuna; 02-04-2020 at 06:06 PM.. |
02-04-2020, 04:19 PM | #5 |
Rep 5
So after reading many different things, upgrading using the standard headunit seems incredibly complicated and expensive, maybe I’ll just get a new standard speaker and leave it alone aha
02-04-2020, 05:05 PM | #6 | |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
I think 🤔 you can code the radio to logic 7 but I wouldn't swear by it. If not, you'll have to get a logic 7 head unit. |
02-05-2020, 12:17 AM | #7 |
379
Rep 2,365
Drives: 2007 E90 323i (Cdn)
Just get a decent used amp, technic harness, and then upgrade the speakers.
L7 not worth the hassle if you're not specifically wanting that. I got my JL 700/5 for less than $200 Canadian (used, mint condition), sufficient to power the whole car (though the under seat woofers are mono in my case). Even a 4 channel amp will do well, and just power the front doors stage.
02-07-2020, 02:51 PM | #9 |
94
Rep 298
Drives: 2011 BMW 335xi
I've been thinking about BAVSOUND upgrade for a while but do not know anyone who has it. You only upgraded 2 speakers? What is the difference? Loudness? Clarity? Bass?
2011 BMW 335i xDrive E92 N55 Alpine White\M-Sport /BMS CAF/HPS CAI/VRSF 5" FMIC/VRSF CP/VRSF Inlet and Outlet/VRSF Catless DP/NGK 1-Step Colder Plugs/xHP Stage 1//MHD Stage 2+
02-07-2020, 04:54 PM | #10 |
54
Rep 291
Just did two midrange and 2 tweeters. Yeah clarity is definitely better. You can just tell crisp and sharper sound. I just got subwoofer too but it will take 12 hours till i can see the result they say. You can just buy the whole kit and try to find separate ones on ebay. I cant think of any other options thats plug and play.
02-07-2020, 10:10 PM | #11 |
54
Rep 291
Tried bavsound subwoofer. It definitely makes huge difference. Im not sure about deep base sound yet. But you can tell drum sound feels more real like listening to the instrument than hearing through filtered speaker. I recommend this along with speaker upgrade. Speaker (voice) subwoofer (beats)
02-09-2020, 12:19 PM | #12 |
94
Rep 298
Great, thanks.
02-09-2020, 02:35 PM | #13 |
Rep 5
I’m planning on sticking a sub in the boot and maybe doing the tweeter upgrade atm, I’m happy with how it sounds other than distortion when I try listening to heavy rap music loud.
I’ve got a Sony amp and sub with a power cap in my loft so might aswell try that out with piggybacking the underseats and playing with the eq’s to see if I can get a good sound out of it all |
02-12-2020, 07:24 AM | #14 | |
1903
Rep 6,968
02-12-2020, 11:13 AM | #15 |
1911
Rep 13,104
When you talk about upgrading speakers without
upgrading the amplifier you have to be clear about which system you are starting out with to compare results . Because the three systems all have different output power on a per channel basis. |
mweisdorfer1902.50 |
02-12-2020, 11:18 AM | #16 |
New Lifetime Replacement Policy
816
Rep 11,738
I'm running the Bimmertech Alpha One in my DD, it's a complete direct replacement speaker upgrade. Massive difference in the fullness of sound and bottom end.
-James |
02-16-2020, 03:54 AM | #17 |
Rep 5
I don’t think I’m as fussy as you guys about sound quality, I have the base system.
Any of you guys know where to get signal from for an amp and sub? Seen a few things with twisted wires but I’m guessing those are for one of the better systems. |
