usb retrofit?
02-01-2020, 03:43 PM | #1 |
Rep 4
usb retrofit?
Hi guys. I was wondering if i can fit usb socket under armrest in my 2010 e90. I have CiC business navi with aux under armrest bluetooth just for calling and receiving calls. I saw in some other e90s that they have usb socket next to the aux. So, thanks guys.
02-01-2020, 08:13 PM | #4 |
1911
Rep 13,104
As I said in the end of the last response.
Look in the entertainment system pdf for the location of these modules. I think its number 3 in the list. Running your vin through a vin checker such as mdecoder.com can sometimes tell you if you have a combox. http://www.e90post.com/forums/attach...2&d=1260829447 The modules are in the same location as the TCU in the above document. Sometimes the Mulf 2 Hi is found underneath the TCU module. |
02-02-2020, 06:01 AM | #6 |
456
Rep 2,749
if you replace tcu with combox you will get usb audio and bluetooth streaming
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
02-02-2020, 03:19 PM | #9 |
1911
Rep 13,104
There are many combox retrofit thread's here and Internet
Wide if you search for them. https://www.e90post.com/forums/searc...rchid=64078125 You will also need coding and with an Icom cable for Most Bus modules and the head unit. |
