01-29-2020, 04:06 AM | #1 |
Rep 14
Replacement CIC basic Head unit missing USB functions, etc
Hi. My 2012 head unit (CIC with no hard drive, no nav), died and i bought a replacement from eBay. exact same model;
https://www.ebay.co.uk/itm/BMW-1-2-3...72.m2749.l2649 Works fine. Radio plays, reverse sensors work but there's a couple of things missing.
With no USB i cant play my tunes or even update the firmware. I've got E-Sys and an enet cable but not coded before. None of the F30 "cheat sheets" mention USB connectivity as an option. I've checked the connections on the device and it seems okay so either...
All advice welcome. |
01-30-2020, 02:36 AM | #3 |
Rep 14
I've seen lots of guides to add features to iDrive but none to just code replacement head unit to car.
Do i need to buy fsc codes? its basic head unit with no maps or hard drive. Do i need to wipe it first or can i just change vin with e-sys? |
01-30-2020, 10:23 AM | #4 | |
588
Rep 2,302
But nevertheless you should/can code the HU to your car. For that you have to open E-Sys, mark the HU, then on the right side "detect caf for swe", choose a CAFD and hit the button "Code". That was the short form. |
02-17-2020, 09:11 AM | #6 |
Rep 14
Hi. Finally tried it. under my "HU" ECU folder, there is no CAFD file. There is an IBAD file, which no other ECU has. I couldn't see how to enable the "detect CAF for SWE" option. It's greyed out.
Thank you in advance for your patience! |
02-17-2020, 10:06 AM | #7 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
I’ll help through Teamviewer. Please send me a message.
02-17-2020, 10:06 AM | #8 | |
BimmerPost Supporting Vendor
665
Rep 1,976
Drives: 2020 G20 320i M Sport
Looks like you have an ENTRY HU so even if you're able to code it, the USB and Bluetooth will remain locked as these require FSC codes.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
Poochie9104.50 |
02-18-2020, 03:16 AM | #9 |
Rep 14
Thanks but at work ATM
I bought it off eBay, so i need FSC codes to enable functions that are locked to my VIN? How do i get those? Coding n00b question i know |
05-11-2020, 06:17 AM | #10 | |
Rep 14
Thanks |
05-12-2020, 03:00 AM | #11 |
Rep 14
I found this guide to extract FSC. Will this give me what i need? then i'll have to wipe the HU and start from scratch?
http://obd365.eklablog.com/how-to-re...sys-a130376808 |
07-26-2020, 07:44 AM | #12 |
Rep 14
Yip, I'm in the same boat as you.
I need to replace my basic HU Entry L7. (no nav, no DAB, no combox...) I already know how to add/remove FA options/VO code (using esys) that will be relevant to my vehicle, though no idea about changing the VIN and any associated FSC codes. There are so many threads about people solving their problems, though it's really difficult to find a definitive DIY guide for the VIN change etc. |
