Wire that controls Gong on 2011 LCI e90 with HiFi
01-28-2020, 11:58 AM | #1 |
Rep 63
I'm wondering if there is a wire on the radio harness that controls the gongs (seat belt, doors, TPMS failure, temperature, etc). If possible, i'd like to cut this since the gongs are starting to drive me crazy.
I pulled the radio out the other day and took photos - i can post if needed. In looking up the radio diagrams, I've found the speaker (pre-amp) outputs, but there are about 4 to 5 other wires on pins 9-16 that I cannot find what they do. I'm hoping 1 is the gong signal that can be snipped. 2011 e90 LCI with HiFi stereo that has Satellite Radio option Anyone here know? |
01-28-2020, 02:17 PM | #2 |
1911
Rep 13,104
I believe its comes over the bus and is not a single wire.
Can bus(you wouldn't want to cut that) Gongs can be modified in software some of them like the seatbelt or key still in slot with door open can be turned off with software changes. See the coding sub forum. Get a coding cable and downloads from Bimmergeek.net or there Pro Tool for a phone . The Pro Tool has canned routines that can do this stuff and is easy to use the coding cable and downloads are more powerful but require effort and some tech abiltiy to setup and use.(on a PC) http://ncs-expert.com/wp-content/upl...st_v1edit.xlsx Go to the e9x code list tab on the Excel page the above link opens to see the possibility's. If you live at the Summit don't set up self locking unless you want to freeze waiting for the locksmith. The coding sub forums have DIY's for most of this stuff. Diagnostic Manuals Inpa/Ista D https://bimmerprofs.com/diagnostics-inpa-part-1/ https://www.google.com/url?sa=t&rct=...7x8H3pN8h1fMuF https://carmod.ru/files/icom/istad_en.pdf https://www.e90post.com/forums/showthread.php?t=1681573 https://www.bimmerforums.com/forum/s...-P-actually-do primary links https://www.bimmerfest.com/forums/at...9&d=1539905743 https://www.e90post.com/forums/showthread.php?t=1681573 https://www.nathansbmwworkshop.com/b...or-dean-videos If you don't want to deal with doing this yourself see if you can find a coder to do it for you . https://www.e90post.com/forums/showthread.php?t=1357699 Last edited by ctuna; 01-28-2020 at 02:41 PM.. |
01-29-2020, 08:02 AM | #3 |
Rep 63
Thanks, good advice.
I bought the k+dcan cable a year or so ago, but haven't done much else because my only laptop is a work one that I can't install software on. I should just buy an old pc on eBay and take a crack at it. Anyone know someone in Denver area that I could bribe with beer for either some coding or tutorials if I get my own? Cheers! |
01-29-2020, 10:28 AM | #4 |
1911
Rep 13,104
If you are going to look for coders you should to it on the coding
sub forum. Those links I gave you have plenty of downloads and tutorials on how to code. |
