01-24-2020, 09:04 PM | #1 |
389
Rep 376
I did a search couldnt find anything on this besides the side marker.
Is there a way to code off the amber turn signal bulb in the headlight when the lights are on? |
01-25-2020, 10:06 AM | #3 |
844
Rep 2,364
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Yes. Used Bimmercode as well. Very easy to code out
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
Osirisman389.00 |
01-25-2020, 05:08 PM | #4 |
389
Rep 376
Do you know the actual setting name ?
01-27-2020, 02:33 PM | #5 | |
844
Rep 2,364
Follow my builds:
01-27-2020, 11:17 PM | #6 |
Luxury at the redline :)
9105
Rep 7,563
It's under the FEM menu in Bimmercode..
I actually coded mines off but repurposed and modded the front fog light button to control them, on cue.. . |
Osirisman389.00 AndrewC198910932.50 |
01-28-2020, 02:33 PM | #7 |
Rep 23
Nice! How did you mod it sync with the foglight button. I just recently turned mine back on due to the super strict laws here in Vancouver Canada.
01-28-2020, 06:49 PM | #8 | |
9105
Rep 7,563
First, follow Andrew's instruction below to mod the headlight switch, activating the front fog light function but instead of coding it to control the the Angel Eyes rings, as the thread indicates, you're going to repurpose it to toggle the front side markers, with values highlighted in red. Front Fog Light Mod https://f87.bimmerpost.com/forums/sh....php?t=1646587 FEM > Expert Mode > 3060lcemaster: nsw_verbaut > verbaut 3063lcelampmapping2: mapping_nebelschw_l_output: [COLOR="DarkRed"]0X0D[/COLOR] mapping_nebelschw_r_output: [COLOR="DarkRed"]0X0E[/COLOR][COLOR="DarkRed"][/COLOR] |
01-30-2020, 03:16 AM | #10 | |
9105
Rep 7,563
I have get the parameters together for changing the priority. When you're done above process above, tag me here and I'll guide you from there. It's best to do it one at a time so it doesn't get confusing. |
02-01-2020, 08:23 PM | #11 | ||
9105
Rep 7,563
Mapping_Nebelschw_R_Priority: [COLOR="DarkRed"]0X01[/COLOR] Mapping_Nebelschw_L_Priority: [COLOR="DarkRed"]0X01[/COLOR] Mapping_Blinken_Z_R_Priority: [COLOR="DarkRed"]0X00[/COLOR] Mapping_Blinken_Z_L_Priority: [COLOR="DarkRed"]0X00[/COLOR] Mapping_Blinken_V_R_Priority: [COLOR="DarkRed"]0X00[/COLOR] Mapping_Blinken_V_L_Priority: [COLOR="DarkRed"]0X00[/COLOR] So what you're doing is reversing the "priority" from the front fog light/side marker. The 0X[COLOR="Green"]01[/COLOR]/0X[COLOR="Green"]00[/COLOR], the lower the number, the higher the priority. The higher number, the lower the priority. The mapping above "blinken" - one represent the turn signal priority and the other is the hazard lights. I'm not certain which is which but code it all together and you should be fine. |
02-01-2020, 08:35 PM | #12 | |
10933
Rep 4,551
Drives: 2015 328d xDrive
Awesome, thanks I'm going to try it out now. |
Poochie9104.50 NYC Bimmer259.50 |
02-04-2020, 11:43 AM | #13 | |
14
Rep 64
I thought side marker mapping was (0x32 & 0x33) |
02-04-2020, 12:40 PM | #14 | |
10933
Rep 4,551
https://f87.bimmerpost.com/forums/sh....php?t=1691279 |
