01-24-2020, 08:36 AM | #1 |
606
Rep 1,782
HELP: Oil in cylinders
So I dropped my car off at the dealer for low power, blue/some sort of smoke from tailpipes
I know the car needs a VCG which I brought it in to replace anyway. I was driving the car fine and all of a sudden I lost power and felt like DME limited surge if that makes sense. Car is getting blow by in at least 3 cylinders according to the dealership. As I said, it needs a VCG. I'm not sure how oil could be getting into the cylinders. They said no oil was behind the turbo. HPFP is fine however I'm not sure what the issue is aside from the VCG. The car is Tuned on BM3 Stage 2 OTS nap on 93. Has Downpipe and fmic. Vehicle has 118k miles on it. I was creating some hypothesis' on this an I was told VCG and PCV could be the culprit. No codes are displaying except Low boost pressure. Not really sure where to go from here. The dealer wanted to charge me another 3-3.5 hrs of labor to do a compression and leak down rear in the motor but that's about 500 or so bucks. They are saying it could be scoring in cylinders or ring failure. Not sure where I should go as this could get extremely expensive. Please leave any thoughts and ideas to aid me in this. But beside myself as I love my little car but I need to sort this. I don't have the car back yet as I'm trying to figure out this stuff for the weekend. I will try and get the car back to log it and send that off to a few people to see what a tuner can say from that standpoint. I hate bringing it to the dealer but my Indi shop was booked till Monday so I needed a car and basic prognosis. It's not letting me upload a video of the car from my phone but I'll post it in comments. Thanks for the help.
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
01-24-2020, 02:25 PM | #2 |
4368
Rep 7,620
You can try doing logs to see if you can explain the loss of power based on the data in the logs, but they aren't really going to help you answer the blue smoke question...
Don't know what you mean by "DME limited surge". How did the dealership conclude you are going blowby in 3 cylinders without doing a compression or leak down test? How do you know there is oil in the cylinders, aside from inferring from the blue smoke? Is your downpipe catless? If you really want to know the internal health of the engine you do need to do the leak down and compression test. You can however start with the "free" option of logging first, assuming you want to do a WOT pull on a potentially hurt engine... How old are the plugs? |
OUGrad05526.50 |
01-24-2020, 03:46 PM | #3 | |
527
Rep 865
2023 i4 eDrive40
2022 Acura MDX |
01-24-2020, 04:40 PM | #4 |
4368
Rep 7,620
Another thought - you should be able to tell if you have excessive blowby by checking your inlet pipe (right after where the PCV hose connects, before the turbo) and/or by dropping the IC and check the TIC, IC, and CP for oil buildup. If the issue is your rings and crankcase pressure (typically what people mean by "blowby") then you should see strong evidence of excessive oil buildup in those locations, especially if it was enough to produce blue smoke.
As i was typing that yet another thought - blown turbo. If you do NOT have any evidence of blowby yet you have a low boost code and you are getting blue smoke in the exhaust, you could have a blown turbo. It would explain both of those symptoms. If you mileage is that high and you have been running that tune for a while and drive the card hard, its not a crazy scenario. |
ronanz1822.50 Chicken_Joe606.00 |
01-24-2020, 05:52 PM | #5 | |
Gettin It Figured Out
1823
Rep 2,669
This ^^ Highly likely.. .
01-25-2020, 12:03 PM | #6 | ||
606
Rep 1,782
01-27-2020, 08:21 AM | #7 | ||
606
Rep 1,782
01-27-2020, 08:23 AM | #8 | |
606
Rep 1,782
01-27-2020, 11:54 AM | #9 | |
4368
Rep 7,620
If the turbo failed and the oil came out of the exhaust turbine side, i imagine that would be clearly visible in the downpipe and/or back of the turbo with DP removed. If they had the DP off they should have been able to check for shaft play. I think a compression test is in order at this point, and a oil sample is a good idea. |
01-27-2020, 01:11 PM | #10 | ||
606
Rep 1,782
01-27-2020, 01:43 PM | #11 | |
485
Rep 1,105
Hope you get yours sorted out my friend!
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
01-27-2020, 01:48 PM | #12 | ||
606
Rep 1,782
MAKH 588.50 |
01-27-2020, 02:54 PM | #13 | |
1823
Rep 2,669
Damn.....great point! .
01-28-2020, 09:48 AM | #14 |
606
Rep 1,782
Update the car is having leak down and compression test done. The tech wants me to flash the car back to stock so he can read misfires. Updates will continue. Thank you for all of the input!
ronanz1822.50 |
01-28-2020, 12:52 PM | #15 |
606
Rep 1,782
Update: car had compression and leakdown done. Numbers are as follows:
Compression: 1: 190 2: 160 3: 185 4: 210 5: 200 6: 185 Leakdown: 1: 60% 2: 7% 3: 20% 4: 7% 5: 8% 6: 22% Also told me turbocharge was FUBAR and has sagging shaft and multiple bent turbine fins. I'm honestly BIG sad
01-28-2020, 01:53 PM | #16 |
4368
Rep 7,620
Dang, not great news...
Did they give you any more information on the leakdown test? In other words, was the air escaping into the crankcase (rings), out of the intake (intake valves) or out of the exhaust (exhaust valves)? Interesting that #2 has the lowest compression but a OK leakdown test. I think you need to take a look at the cylinder walls. I find it a little odd that the problem happened suddenly... Perhaps the turbo failure was sudden (loss of power and low boost code), but the wear had already been happening slowly over time? |
Chicken_Joe606.00 |
01-28-2020, 01:55 PM | #17 | |
606
Rep 1,782
01-30-2020, 07:56 AM | #18 |
36
Rep 59
Can you elaborate on this? Other than the typical gasket leaks and some failures after replacing the OFHG, I haven't seen that many threads about these types of engine problems occurring specifically in 2013s. You've seen different?
01-30-2020, 11:21 AM | #19 | |
1106
Rep 1,499
Bore it out, partially build the engine (new pistons and rings) and throw a big single turbo on there
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
01-30-2020, 11:23 AM | #20 | ||
606
Rep 1,782
01-30-2020, 11:27 AM | #21 | |
1106
Rep 1,499
Yeah if your cylinder walls are ok then upgraded rings is a good option. Did they scope it?
01-30-2020, 11:43 AM | #22 | ||
606
Rep 1,782
