No bass
01-19-2020, 01:42 PM | #1 |
105
Rep 277
No bass
07 328xi with Jodi sound system. Sub under drivers seat isn't working at all, but sub under passengers seat works just fine. I'm going to try and swap the sub from passenger side vice versa. If the drivers side sub still doesn't work, is there a way to disassemble and repair the subwoofer? Or am I better off buying a new one? I'm assuming since the passenger side works it's not amp related
If you aint first, your last.
01-19-2020, 05:35 PM | #4 |
1911
Rep 13,104
You can get used Hi Fi speakers on ebay or in the buy and sell section here.
You can also get the Hi Fi amp in the same places and they are pretty cheap and easy to install. Also be aware that there is almost no output from the Hi Fi system underseats even when it works correctly. It's a really weak system overall that fall's right apart if you try to turn it up at all. The weakest piece is the amp and the speaker are not that far behind. |
01-19-2020, 05:37 PM | #5 |
105
Rep 277
But is there a way to repair the subwoofer itself? I also read something about the amplifier channel is blown and could be replaced?
01-19-2020, 05:48 PM | #6 |
1911
Rep 13,104
Unless you go out and buy the chips yourself and plug/solder them in
does it make any sense to repair and amp when you can get it used one for less than 100 bucks on ebay and it's only a single plug connector that detaches the amp with the throw of a lever. Plus you will not find anything but a block diagram for a schematic.' Same goes for the speakers used once are super cheap on ebay . And I am talking about factory OEM replacements in both cases. This overflow of used parts comes from people that have upgraded to aftermarket stuff of just wrecked e9x's. There are places that sell re-cone kits for speakers and even repair them but unless you they for something special it does not make any sense to do so. Last edited by ctuna; 01-20-2020 at 12:47 PM.. |
01-19-2020, 05:52 PM | #7 | |
105
Rep 277
01-19-2020, 05:55 PM | #8 | |
105
Rep 277
01-19-2020, 06:51 PM | #9 | ||
9
Rep 36
Drives: %E2%80%9802 330ci vert, E2%80
01-19-2020, 06:52 PM | #10 | |||
9
Rep 36
Vinnief96104.50 |
01-20-2020, 11:04 AM | #12 | ||||
105
Rep 277
gbmw3119.00 |
04-13-2020, 05:13 PM | #13 |
Rep 14
01-25-2021, 09:43 PM | #14 | |
105
Rep 277
