BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > 2012 BMW 1-Series Sporthatch (F20) Discussion > 116d running bad low load
      01-18-2020, 02:51 AM   #1
Vezzel
Drives: 116d
Angry 116d running bad low load
Hi!
I have bougt a F20 116d 2,0 from dec. 2013, 150.000km, as defective.
Diesel ran into engine-oil. Replaced hi-pressure-fuel-pump and that problem was solved.
Engine starts fine, but has a lot of misfires when running at light load / steady speed.
When engine is under load/accelerating it runs fine.
Idling and rev'ing the enginge in neutral is fine too...
No errors stored in EDU.
It has some engine-knocking under load up to 12-1500rpm.
When unplugging the air-mass-meter-sensor the engine without misfires - but still some knocking when it under load at low RPM's.
Replaced the air-mass-meter, but still same problem.
Do you have any idea?
      01-18-2020, 02:59 PM   #2
Setright
Car Enthusiast
Setright's Avatar
Denmark
20
Drives: 120i M-Sport 2022
Sounds like you solved the problem.
My best suggestion is to shift one gear down. Below 1500rpm there is no boost from the turbocharger.
      01-18-2020, 04:14 PM   #3
No one
1045
Drives: F21 118i
I had to search how a diesel could misfire (there are no spark plugs). The first result has a list of suggestions as well: https://www.quora.com/What-is-the-ca...re-in-a-diesel.
      01-19-2020, 02:10 AM   #4
Vezzel
Drives: 116d
Ok - I will try do describe it in another way - the ingine behaves like it does not fire on one or more cylinders for a split-seconds when driving at a steady speed. When the car is accellerating there is no problem...
      01-30-2020, 11:36 PM   #5
M135imike
7
Drives: F20 m135i
Possibly crank sensor or something alike?
      12-23-2023, 01:41 PM   #6
KK0124
Drives: E91 320D N
Did you manage to get this sorted? I have a similar problem with mine
