01-16-2020, 12:19 PM | #1 |
177
Rep 211
Wheel Trim... Anyone changed it?
Has anyone changed the trim on the steering wheel? Seen the M Performance wheel fitted to a couple but not just the trim.
01-16-2020, 01:22 PM | #2 |
USA
129
Rep 217
https://x3.xbimmers.com/forums/showthread.php?t=1676452
I purchased and installed the CF trim and paddles from RG Sport and it looks just like his pics. You do not need to remove the steering wheel as noted. Once the paddles are off, you can access the 3 screws holding the trim in place. You will however need a smaller torx T6 (IIRC) to move the buttons and switches. |
01-16-2020, 04:10 PM | #3 | |
177
Rep 211
01-16-2020, 05:40 PM | #4 | |
177
Rep 202
01-16-2020, 07:44 PM | #5 |
USA
129
Rep 217
r33_RGSport12972.00 |
01-16-2020, 07:50 PM | #6 | |
USA
129
Rep 217
Yes, you would have to remove the airbag for either install. Very easy to do and disconnect the negative battery terminal first. Last edited by j080808; 01-16-2020 at 09:28 PM.. |
01-19-2020, 05:13 AM | #7 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3512
Rep 4,211
I know this is not an X3 M but this steering wheel trim is for the The G series/F series M sport steering wheels and M wheels. BMW OEM M Performance part. Also the M Performance Carbon paddles as well. This particular trim is carbon/alcantara. This part just recently became available for the US.
08-28-2021, 08:04 PM | #8 | |
Rep 4
How does the trim pop out? I must be doing something wrong, I got the battery disconnected, took air bag out, loosened T20 at bottom of wheel on backside, but the trim that in already won’t come out.. |
08-28-2021, 10:27 PM | #9 |
USA
129
Rep 217
There are two more T20's at the 9 and 3 position (on the backside, like the one at 6). To access them, remove the paddles via the T20's holding them in. Follow the wires leading to the paddles, you will see the bolt.
