01-15-2020, 11:59 PM | #1 |
28
Rep 100
F36 Coilovers - limited selection?
I'm ready to pull the trigger on entry level coilovers. The goal is to close the wheel gap and be somewhat low. I don't mind a stiffer ride. I had coils on my last car and they were very stiff.
I've searched here and various other websites to see exactly what my options are but it looks like I'm somewhat limited to ST and KW v1. I was set on BC's but I don't see F36's as an option on their website. So, my F36 people, what other options are there? If you have experience with any of these (specifically F36 models), what are your thoughts? Recap: ST vs Kw v1 - Galvanized vs Stainless Steel Vogtland - F30 only Fortune 500 - F30 only BC - F30/32 only I live in SoCal where we don't get snow (Huntington Beach) nor do I have to worry about salt. |
01-18-2020, 02:55 PM | #2 |
993
Rep 1,934
All of those will fit. The spring rates may not be optimal but it will bolt up no problems.
On top of that you can go Fortune or BC and get custom swift springs to make up for the extra weight. Dampening would be adjusted for on the shock dial.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
01-18-2020, 09:10 PM | #3 |
22
Rep 121
I believe the ST now have the ST XA's with damping adjustment that fit the F36. I think I may be leaning towards those as I'm in San Diego. $1,189 on their website. I've been going back and forth too which way to go on my F36.
DeeM5527.50 |
01-19-2020, 07:01 PM | #5 |
Cheapskate
4450
Rep 4,993
ST is the best budget option out. BC coilovers will work but they aren't ideal in my experience. Noisy and they get a lot of corrosion.
01-20-2020, 11:10 AM | #6 | ||
28
Rep 100
If the spring rates are not optimal, and with the F36 being about 200+ pounds heavier than the F32; does that mean the springs/ride will be bouncier or will I feel the impact a bit more when going over bumps/dips? Quote:
I just checked the website and I only see ST as an option for the F36. If the XA's are an option then that would be my number one choice. I'll give them a call. |
01-20-2020, 11:33 AM | #7 |
993
Rep 1,934
No, that's what the adjustable dampening is for.
01-20-2020, 11:37 AM | #8 |
480
Rep 681
If you go for a set that's designed for an f30/32, the rear springs will likely just be undersprung. That results in a more crashy ride and will also make the car feel more easily upset. You could compensate for this with dampening but it'll never feel right. You can swap the rear spring out for something stronger. Its not too bad but it is a bit of extra work.
Fwiw, KW V1s come in a config for the f36. It has a stronger rear spring and adjusted dampening to compensate for it.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
335JTSD21.50 |
01-20-2020, 12:45 PM | #9 |
28
Rep 100
Just called ST and the XA's are $1,399. For a $100 more, the KW V1's will get us the lifetime warranty.
01-20-2020, 02:16 PM | #10 |
22
Rep 121
I was quoted $1,189 and confirmed on their website by searching the part # given. Is that with camber plates for the $1,399? Part #1822000J I was given to me and told did not include camber plates.
01-20-2020, 03:10 PM | #11 | |
28
Rep 100
I just realized that they gave you the "Your Price" on their site and quoted me the MSRP price. |
335JTSD21.50 |
01-21-2020, 06:10 AM | #12 | |
Cheapskate
4450
Rep 4,993
what people don't think about is that the ideal suspension setup will differ for everybody. Some like a soft rear, some like it stiff (pause) so just because you don't like it doesn't mean it's undersprung. These setups are modular and KW, H&R, Swift, etc. all sell their springs separately for a reason. But it won't suddenly make it feel like you're driving a boat. |
01-21-2020, 12:38 PM | #13 | |
480
Rep 681
I'll agree this is my opinion and most consumers will be fine with whatever stuff comes out of the box. I know very well that these systems are modular as I have different springs will be getting custom valve work done to the shocks of my b14s as well.
2006 997.1 C4S |
01-21-2020, 01:28 PM | #14 | |
Cheapskate
4450
Rep 4,993
01-21-2020, 01:56 PM | #15 | |
480
Rep 681
FWIW, I found the KW V1 springs a bit too soft for me so I was crashing over larger bumps or consecutive bumps. If I was only using them on the street, I'd prob of lived with them since the ride was nice the majority of the time. But with more textured roads or track time, I think I'd of swapped the springs and revalved those too. Its also funny you bring up Ohlins because they're the only manu that has any flat ride out of the box. Its a bummer they don't make an xdrive kit. That pesky shorter front strut on xdrive cars is a real bummer haha.
2006 997.1 C4S |
01-21-2020, 11:13 PM | #16 |
22
Rep 121
For somebody who has very little knowledge about spring rates and damping...would you recommend reaching out to somebody like Fat Cat to piece a better than out of the box system together? I've only recently learned about what flat ride is and I thought these coilovers were a lot better than people are making them out to be. Thanks!
01-22-2020, 12:55 AM | #17 | |
480
Rep 681
2006 997.1 C4S |
335JTSD21.50 |
01-22-2020, 02:00 AM | #18 |
1599
Rep 3,748
So far for my choices as replacement suspension for my F36 will be
KW street comfort or eibach /koni SA I'll be following this thread. Hope to gain some more choices. The car is DD and I'm not planning to track the car. |
01-23-2020, 11:39 PM | #19 |
22
Rep 121
Are there more benefits to the KW Street Comforts besides the obvious smoother ride? Valving and springs optimized for comfort compared to more performance? Thanks!
02-05-2020, 01:39 AM | #20 |
1599
Rep 3,748
Speaking of coilovers on another thread, someone mention Tein coilovers specifically it's the FLEX Z coilovers... just went to there website spring is 6 kg Front and 10.5 kg.
I read somewhere in another thread that people order swift spring custom with 8 kg front and 14 kg rear. Is stronger spring really needed for everyday driving? |
02-05-2020, 06:55 AM | #21 | |
Cheapskate
4450
Rep 4,993
Also keep in mind that Tein, BC, Fortune Auto, etc. are all pretty much the same. |
02-05-2020, 02:53 PM | #22 |
873
Rep 1,079
How's your experience with V1? I'm looking for options for my F32 xDrive. Considering B14, B12 kit, V1 and Street Comfort. Just worried rear 1.4" minimum drop of V1 might be too much for Wisconsin. Also worried drop on B12 kit might be too minimal, the xDrive front wheel gap is ridiculous, rear seems pretty good so 1.4" drop will be too much.
