01-14-2020, 08:36 PM | #1 |
Road Warrior
66
Rep 152
MSS Sport Fully Adjustable Kit
Hi guys! Just thought I'd mention that I just ordered this suspension upgrade for my 540xi Msport. It actually looks really slick and is very will reviewed in the Audi community. MSS is relatively new to BMW but they were very responsive to my many questions and are very confident this will be a nice performance upgrade while also providing an adjustable drop height. Pretty cool.
https://shop.mss.company/shop/mss-sp...loon/?make=bmw
2018 540xi M-Sport | Alpine White * Black Nappa * Harman Kardon * 20” 668m Rims * M-Sport Brakes * MSS Fully Adjustable Springs * 20% Ceramic Tint * Gloss Black M Grills * bootmod3
01-25-2020, 11:27 PM | #3 |
Road Warrior
66
Rep 152
Suspension has arrived. Having installed this week.
01-31-2020, 08:58 PM | #4 |
Road Warrior
66
Rep 152
Here’s the look at max drop. By the way, I’m going to adjust it back up about a half inch as this is a tad too slammed for me.
TexasM550i62.00 |
02-01-2020, 09:42 PM | #5 |
Road Warrior
66
Rep 152
I gotta say I’m thoroughly impressed with this suspension. It seems to do exactly what MSS promised. Standard ride is comfortable but when the springs compress under load they stiffen considerably. I’ve been blowing through roundabouts giggling. Historically there’s always been a trade off to stiff sport springs. Great performance but bumpy ride on imperfect surfaces. Not so at all with this MSS kit. This is particularly impressive considering how low I’m riding. (I went with max lowering height.)
Only negative is that the “adjusters” which control ride height are not accessible without removing the suspension. So the dream of easy adjustability is not achieved. If they need adjustment, the car is going to the shop.
dweomir0.00 |
02-15-2020, 11:58 PM | #6 |
163
Rep 321
How much were the springs? Did you DIY install or get someone to do it? DIY'd shocks/struts/springs on my old E90 and man was it a PITA (not particular hard just time consuming and annoying AF). I did save like $800-$1000 which was the labor rate which I was quoted for all four corners.
Also, you mentioned that they are comfortable over imperfect road surfaces, but super stiff when cornering/under load. I've been wanting to increase stiffness especially when cornering hard. My E90 had Eibach Pro springs which were SUPER stiff, but a bit "bouncy" on bumps on the highways. Do these springs really offer the best of both worlds (as stiff as Eibach/H&R around corners, but as compliant as stock M-Sport springs on rough road surfaces)?
2018 G30 540i xDrive M Sport | Carbon Black Metallic | KW V3 Coilovers | F90 Suspension | F90 Brakes | 20" HRE FF10 Liquid Black Wheels | Michelin Pilot Sport 4S Tires | Ivory White Dakota Leather | Carbon Fiber Trim | Executive Package | Bowers & Wilkins Diamond Surround Sound System | JL Audio 12W6v3 and XD600/1v2 | Ceramic Controls | BM3 Stage 2+ E50 ECU Tune | xHP Stage 3 TCU Tune | Dorch Stage 2 HPFP | MST Cold Air Intake | FTP Chargepipe | AA Catted Downpipe | Remus Catback Exhaust
02-16-2020, 05:44 PM | #8 |
Road Warrior
66
Rep 152
Stock was M-Sport suspension. I’m not sure if there are any issues with the MSS kit and DDC. I’d shoot a note to MSS and ask. They were very responsive to my inquiries. Just keep in mind there on England time. 😉
luke1990134.50 |
03-22-2020, 03:11 AM | #9 | |
Rep 2
After checking a couple of videos and found the installation manual online MSS kit on M2 GTS (at around 4:00) mentions that they MSS is modifying the kit so that adjuster sit at the bottom instead of the top, so adjustments can be done easier. MSS installation manual for 5 series https://mss.company/wp-content/uploa...Series-IMs.pdf Just wanted to confirm that the adjusters were installed at the bottom of the spring near the perch/MSS OE bearing parts, and that you still need to remove the suspension to make any adjustments? Thank! BTW awesome looking car! looking for some lowering springs myself and a bit torn between the Eibach Pro-Kit and this MSS. Guys in the video says that Eibach make the springs for MSS (spec) (0:35) |
TMack65.50 |
03-24-2020, 07:56 PM | #10 |
Road Warrior
66
Rep 152
Yukon, get the MSS kit and don’t look back. The more I drive it the more I like if.
07-24-2020, 04:20 AM | #11 | |
135
Rep 296
The spring is too big to fit inside the adjuster and sits on top of it and just moves around. See video here and here. In set of the adjusters there are cutouts - but very narrow ones -> like 1mm Should the spring sit inside there? like on this pic: View post on imgur.com I cant imagine it can be like that. Adjuster is aluminium -> the spring will scrape it to even get inside with weight applied. Im thining they sent me wrong adjuster. Thanks for any help! Just want to make sure Im doing it right |
09-13-2020, 09:16 PM | #12 |
Rep 2
Unfortunately I haven't ordered the springs, due to other priorities, so I don't know for sure.
Looking at the video and comparing it to the pictures from a vendor page here in the US. Seems like the springs should sit on the outside? Since your in Europe may want to email MSS directly to see if something is wrong? https://www.torqued.io/mss-bmw-5-ser...8aArAlEALw_wcB |
09-20-2020, 07:37 AM | #13 | |
67
Rep 203
10-03-2020, 01:33 PM | #14 |
1633
Rep 2,282
Interesting to hear how your getting on with the new springs...
I'm looking at changing mine and was all get to go Eibach but have recently hear good things about MSS. Eibach manufacturer the springs for MSS I heard too. Are you running Spacers on the car too?
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
11-30-2020, 11:22 AM | #15 |
1633
Rep 2,282
IG: project540ix
itzryyster36.50 |
07-26-2021, 05:59 AM | #17 |
Rep 27
11-20-2021, 06:59 PM | #18 |
70
Rep 271
Anyone else tried these springs? I want to pull the trigger for my 2021 M550i but I see hardly any reviews online for my model.
2021 M550i
BMS Pedal tuner JB4 |
11-20-2021, 10:30 PM | #19 |
505
Rep 501
I got them on my 540i in NYC. Gives the car the perfect drop IMO and is not bouncy at all. Feels just like stock but lower and can take turns faster! I definitely recommend em. They raised the price by like $400 from when I got them in April/May this year.
itzryyster36.50 |
11-21-2021, 12:30 AM | #20 | |
171
Rep 255
