01-13-2020, 01:58 PM | #1 |
Rep 12
Cold start up issue ( attached video )
hello ,
I have a random issue ( it doesn't happen each cold start up ). when hot , start up is normal. Car: 2104 435i N55 Issue: sometimes it seems engine is going to stall when starting up. Codes: no codes found. outside temp : 4ºC to 18ºC other symptoms: none. car has 89000km and the only mod done is an ER charge pipe. video: https://gofile.io/?c=Q8DmHY at 4s is when idle goes down and ECU wants to correct it. any ideas? many thanks. |
01-13-2020, 02:25 PM | #2 |
1106
Rep 1,499
Are you tuned?
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
01-13-2020, 03:12 PM | #4 |
485
Rep 1,105
How old is your battery?
I also have a 2014 435i and during this past "cold" months we had in FL I experienced longer delays to start up and once I replaced the battery all was right again!
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
01-16-2020, 06:31 AM | #5 | |
Rep 12
My battery is 5.5 years old. in my case it is not a delay when starting up, it is like it is going to stall. will keep a look at the battery. is there any way to know how much charge can it hold now? |
01-16-2020, 07:37 AM | #6 |
224
Rep 832
Drives: Bmw 335i f30 N55 ( sold)
I'm located in Florida so our winter deft wasn't as cold as Yours LOL. BUT, on a few very cold morning when the temp was 40-50 my car started up very weird. Only on those day's. After the cold passed by my car was fine. My battery is a year old. My intake inlet just recently cracked so it makes me wonder if they inlet was on its way out and was already causing issues before hand. As well as sometimes when I would drive I would almost get like a knock or hesitation on WOT.
Again not sure if this is it, but does make me wonder if they were some how linked
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
01-16-2020, 11:21 AM | #7 |
967
Rep 2,655
Check you EKP module and make sure it's in good working order.
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
01-16-2020, 02:56 PM | #8 |
3441
Rep 79,211
If the battery is weak on startup, like it's struggling to crank that would be indicative of a bad battery and time for a replacement. Some auto stores have courtesy batter testers, you could also just buy your own for a nominal fee. I'm not 100% convinced your problem is the battery. With a stock vehicle, there are many things it can actually be. It could be spark plugs, fuel pump, injectors or something else to name few.
01-24-2020, 03:13 PM | #10 |
Rep 1
I had the same issue and mentioned it at the dealer before I had some Dinan work done on my 435. The said it just needed a software update, haven't had an issue since.
