2010 2011 BMW 5 Series Forum F10 Wheel Candy / wish to confirm fitment |
01-13-2020, 08:39 AM | #1 |
Rep 10
Ready to pull the trigger but wanted to receive confirmation these numbers will work
2016 535 x drive M Sport I like the concave look for the rear and have read that 1% difference will not confuse the x drive system. Like the wider look in the back BC Forged KL11 Wheels for - Front: 19x9.5 - Rear: 19x10.5 - Finish: Brushed Black is their gunmetal look - BC Forged Center Caps BC-Forged-Monoblock-KL11-Wheels-ed Michelin Pilot Sport 4S Tires - Front: 255/40/19 - Rear: 285/35/19 Michelin-Pilot-Sport-4-S-Tires-PS4S-A Should I just play it safe and go square setup? Thanks in advance |
01-13-2020, 04:45 PM | #3 |
58
Rep 93
Also unless you want the rear stretched, I would go 295 or 305/30. I put 285s on my 10.5 wide rear and am looking to change them out
E46 330ci
F10 535i M Sport |
01-14-2020, 07:26 AM | #4 |
Rep 10
Run flats the car came with are 245/40/19 all around
Is this the recommended measurements from Germany? I guess I'm just having a hard time trying to find the safety buffer here; because I do prefer the concave look. |
01-14-2020, 10:36 AM | #5 |
1303
Rep 2,591
245/40/19 or 245/45/18 are the OEM tire specs yes. What safety are you worried about? As a lot of post previously stated, just stay under 1% difference between front and back and you'll be fine. Deviating from OEM circumference just affects the speedo/odometer, not much else.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
