01-10-2020, 07:25 PM | #1 |
Rep 25
Hit a massive pothole- Unsure about the damage
Picture attached. Not to sure what I’m looking at damages wise. Purchased a new rim as the previous one was dented and took it to Costco to get it replaced and they pointed this out to me. Left front side wheel spins freely (undamaged side) while the right front side will not spin freely (damaged side). Does anyone have any idea what kind of damage I’m looking at?
01-10-2020, 08:49 PM | #2 |
94
Rep 262
Drives: 2013 BMW 335i M-Sport
You should not be driving this car anymore. You have one of two failures. Either the strut hat is no longer attached or there is a possible failure in the hub carrier. Either way do not drive the car with the tire touching the strut.
This is not normal. |
Polo088161610.00 |
01-10-2020, 08:51 PM | #3 |
Rep 25
I haven’t been driving it at all. It’s been sitting for a week. Combination of bent rim and now this. Only time it’s been moved is it put it off and on the tow truck.
01-10-2020, 08:54 PM | #4 |
94
Rep 262
01-11-2020, 08:59 PM | #5 |
148
Rep 205
Drives: 14 F30 335i xDrive
Most likely this is the same problem I had with my car. After a number of massive potholes, I started to see smoke from, passenger wheel well while driving. Also nicked the front right was significantly lower than the front left. Turned out the extreme force of bottoming our had shoved the shock down in the hub. This can happen if there's not much of a lip, like my Bilstein shocks at the time, and the pinch bolt isn't torqued down enough. The fix is to losses it up, pull the shock back out, and tighten the punch bolt a lot. They're very strong bolts so they can take a lot of torque. Not sure what the factory torque value should be.
01-12-2020, 04:27 AM | #6 | |
6422
Rep 8,501
From memory, the clevis (pinch) bolts which tighten the hub clamp around the mcpherson strut are recommended to be tightened to 100NM. Don't just take word for that though - do check the correct torque.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
Polo088161610.00 |
01-13-2020, 08:49 AM | #7 |
171
Rep 468
Whats after happening here the impact from pothole fully compressed the shock and when it hit the solid end, the strut moved from it sleeve pushing the carried bearing( strut holder) further upwards into the strut.
This can be rectified easily as said above by releasing the shock clamp and adjusting the strut, but the problem is that stop pin on the strut has been sheared off. Therefore you wont be able to perfectly align the strut with the pin broken. I suggest you replace the strut. |
01-16-2020, 10:53 PM | #8 | |
Rep 25
01-17-2020, 01:00 PM | #9 | |
1599
Rep 3,748
12-18-2022, 05:24 PM | #10 | |
Rep 6
My insurance provider is evaluating my claim, but said that it will go in a collision if it does since "I drove over something I should not have"! |
12-19-2022, 05:08 AM | #11 |
2257
Rep 2,048
Over here in the UK any claim, even with a protected NCB, will still lead to an increased insurance premium as the risk element has increased. You will still receive the % discount you were entitled to but on a higher base calculated cost.
Also, are you able to claim against the local authority? I had a similar situation last month and have had the approval through from the relevant council for about £3k in costs; 4x tyres, 2x rims and an alignment. I took the hit on replacing the front control arms myself as I already had a set of Mehle HD ones there ready and it only took an hour or so of my time. |
12-19-2022, 10:41 AM | #12 |
70
Rep 131
Unfortunately, even in the states that do have a process to cover road damage to vehicles, they're bullshit. As an example, here in NJ you can't file if your insurance would cover it, which is just paying for it yourself with more steps. Even if you can file a claim, there's not a huge chance you'll get paid out from the state. For county and local roads any claims are basically a pipe dream.
12-20-2022, 02:15 PM | #13 | |
2257
Rep 2,048
12-26-2022, 08:16 AM | #14 |
Rep 15
I’m always impressed with the amount of abuse from potholes my F30 can take. I’ve hit a few big ones over the years and am scared I’ve broken something. Worse thing was I pinched a sidewall once and it caused a bubble which required a new tire. You guys must be hitting absolute craters in the road to cause damage to the suspension.
01-01-2023, 04:02 PM | #15 |
5886
Rep 10,256
Any encounter with a pothole is less than exciting to say the least. My F36 encounter with the pothole in San Diego area produced a sound that almost convinced that something has been damaged. Yet the inspection revealed no damage.
F3x suspension can absorb quote a bit. The Pirellli run flat served its mission well. I was able to limp along to the final destination. |
01-04-2023, 01:43 AM | #16 |
19
Rep 90
Drives: 435xi GC
Typically when replacing your strut due to damage you’ll also want to replace the steering knuckle as that’s what holds it in place on the bottom end. When the strut is moved out of place/damaged it will cause the knuckle to bend slightly sometimes even undetectable other than a laser alignment machine which was what happened to me. Thought the dealership was trying to up sell me since the knuckle looked fine however after many indies telling me that it looked fine as well i decided to take it to multiple alignment shops and looked at the report myself which were all within spec. Finally found one that had the cross caster value and determined that it was off and had to do steering knuckle as that was what affected caster. Hope this helps as suspension repairs are costly and confusing! These cars are also very finicky as i’ve experience simarly damaged suspension but to a worse degree on Mercedes vehicles but do not alter steering nearly as much.
