BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > E92 Amp/Sub Upgrade
      01-09-2020, 01:56 PM   #1
Lukejenks1201
Drives: Bmw 325d
E92 Amp/Sub Upgrade
Sorry if this has been covered but I can’t seem to find the information I’m looking for.
I have a base sound system in my car with stock h/u and I-Drive, no amp in the boot, I have a feeling this may have been upgraded at some point as the sound quality doesn’t sound to bad but I want a bit more bass, I want to add an amp and a sub, does anyone know of a guide that shows the best way to do this?
Again sorry if this has been covered before but I couldn’t find it.
Thanks.
      01-09-2020, 03:03 PM   #2
ctuna
1911
Drives: 325xi 06 wagon MT
yes it has been extensively covered
Do and advanced search with base system as the topic.
https://www.e90post.com/forums/searc...rchid=63838596
http://www.e90post.com/forums/attach...5&d=1493273253
Download the link inside the above link this is the most comprehensive
gide.
Base System Upgrades
http://www.e90post.com/forums/showthread.php?t=1378833
gide.
base system wiring pre/post 3/09
https://www.google.com/url?sa=t&rct=...tDpLJPcGkw_ui_
http://www.e90post.com/forums/attach...1&d=1411521234
http://www.e90post.com/forums/showth...ghlight=Dotech
http://www.bimmerfest.com/forums/sho...d.php?t=550771
http://www.e90post.com/forums/showthread.php?t=445266
http://www.e90post.com/forums/showthread.php?t=581379
http://www.e90post.com/forums/showthread.php?t=494299
http://www.e90post.com/forums/showthread.php?t=451941
http://www.e90post.com/forums/showth...ht=amp+upgrade
http://www.e90post.com/forums/showthread.php?t=540954
http://f30.bimmerpost.com/forums/sho....php?t=1003810
http://www.e90post.com/forums/showth...1#post16679904
http://www.e90post.com/forums/showthread.php?t=822366
http://www.diymobileaudio.com/forum/...morel-jbl.html
http://www.1addicts.com/forums/showthread.php?t=634957
http://www.e90post.com/forums/showthread.php?t=495855
subwoofer threads
http://www.e90post.com/forums/showpo...2&postcount=66
http://www.e90post.com/forums/showth...t=Ultimate+Sub
http://www.e90post.com/forums/showth...ight=subwoofer
      01-10-2020, 09:54 AM   #3
Ali-E90
Ali-E90's Avatar
379
Drives: 2007 E90 323i (Cdn)
2008 BMW M3  [8.00]
2007 BMW 323i  [8.50]
Yes, covered a lot (and Ctuna has all the right links, as always!).
The easiest way to just add sub/amp is to use technic base harness, and use that to connect the amp.
You could also use a typical LOC (not plug and play like the harness), but just make sure to tap the signal from the underseat woofers, others are likely high passed.
      02-19-2020, 02:03 AM   #4
Dr.Angel1017
Drives: Bmw 328xi 2008
Very easy with a LOC such as LC2i or LC7, tap into your factory subwoofer wires and that's how you get your signals, you'll be able to add a aftermarket amp and install subwoofers.
