01-07-2020, 05:51 PM | #1 |
160
Rep 741
f36 tail light coding
hey do i was trying make my tali light LED operate as my turning signal vs the bulb that comes stock.
Please follow these Steps very carefully: 1. PlugIn your OBD reader and connect Bimmercode 2. Go to REM (Rear Electronic Module) 3. Go to EXPERT MODE - Click Continue on the warning message 4. In Search field - type in MAPPING You should see all the Mapping configs now. Now this is where you will do your coding. Follow the step-by-step coding from below. Change the config/values for each of these settings. MAPPING_TAGFAHRL_H2_L_OUTPUT - sl_2_l MAPPING_TAGFAHRL_H2_L_FUNCTION - Value 0x06 MAPPING_TAGFAHRL_H2_L_PRIORITY - Priority 1 MAPPING_TAGFAHRL_H2_R_OUTPUT - sl_2_r MAPPING_TAGFAHRL_H2_R_FUNCTION - Value 0x07 MAPPING_TAGFAHRL_H2_R_PRIORITY - Priority 1 -- MAPPING_TAGFAHRL_H_L_OUTPUT - sl_l MAPPING_TAGFAHRL_H_L_FUNCTION - Value 0x06 MAPPING_TAGFAHRL_H_L_PRIORITY - Priority 1 MAPPING_TAGFAHRL_H_R_OUTPUT - sl-r MAPPING_TAGFAHRL_H_R_FUNCTION - Value 0x07 MAPPING_TAGFAHRL_H_R_PRIORITY - Priority 1 -- MAPPING_STANDL_H1_L_PRIORITY - Priority 3 MAPPING_STANDL_H1_R_PRIORITY - Priority 3 -- MAPPING_STANDL_H2_L_PRIORITY - Priority 4 MAPPING_STANDL_H2_R_PRIORITY - Priority 4 -- If you also want to disable the orange signal light and only use rear lights for signal, complete the following. if you still want that ugly orange signal light to be in use.. Do NOT change the below values: MAPPING_BLINKER_H_L_PWM_LEVEL_1 - 00 MAPPING_BLINKER_H_L_PWM_LEVEL_r - 00 someone with a f30 did it. i tried to follow the steps but i noticed one difference instead of TAGFAHRL_H2_L MINE reads TAGFAHRL_V_L. Is mine showing a V because it’s a f36? instead of H2?
2016 435i xDrive F36 M Sport - ER CP | ER Catless DP | VRSF 5" FMIC | bm3 stage 2 93 oct | black double slotted grill | AWE axle back exhaust w/102mm diamond black tips | 437m wheels
01-08-2020, 11:01 AM | #2 |
New BMW owner
139
Rep 621
Drives: BMW 316d, BMW F40 116d
No, something doesn't match up.
F30 REM ECU files should be the same as a F36. Search again. |
01-08-2020, 11:03 AM | #3 |
160
Rep 741
thats what i thought too, but i couldnt find anything else...ill check again later after work.... how certain are you that the f30 and f36 REM ECU files are identical?
01-08-2020, 01:29 PM | #4 |
New BMW owner
139
Rep 621
Cause I code them allot...
I own a F30 and I do have allot of customers with F36'ers etc. F2x and F3x are identical as far as I know. |
01-08-2020, 01:57 PM | #5 |
160
Rep 741
ok ill check again after work today. thanks
01-10-2020, 02:59 PM | #6 | |
160
Rep 741
im an idiot smh
01-10-2020, 11:56 PM | #8 |
New BMW owner
139
Rep 621
They are identical in the inside, for the functions etc.
Yet a F2x values are indeed different than a F3x. Glad you found it. |
01-11-2020, 09:28 AM | #9 | |
160
Rep 741
mine is 2016
06-11-2020, 05:06 PM | #10 |
Rep 2
Any idea on getting reverse lights working again using ista+, coding out the errors ? Using diagnostics in ista+ I can turn them on but when setting car in reverse no reverse lights.
