01-03-2020, 09:40 PM | #1 |
17
Rep 35
Spool Performance HPFP Overdrive Unit
Any cars here have it installed? Thoughts? Logs? Numbers?
http://spoolperformance.us/index.php...&product_id=71 Seems like a great coat effective alternative to HPFP replacement options. |
01-03-2020, 09:53 PM | #2 |
7281
Rep 7,457
Overdrive's won't work on the F series n55, direct replacements that increase flow volume are the only solution.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
01-03-2020, 10:09 PM | #3 |
756
Rep 2,149
I looked into this a week or so ago, seems like it's only $160 cheaper than the xdi-35 when you add the micron fuel filter thing. However, I'm unsure if the fuel filter is needed or not. But it says "highly recommended" on their site.
01-03-2020, 10:13 PM | #4 | |
7281
Rep 7,457
Hopefully XDI drops their prices to compete, there is also another company that is launching an HPFP upgrade soon as well according to their IG. They have 2 pumps, stage 1 @ 50% over stock and stage 2 @ 75% over stock which both beat out what XDI has to offer.
01-03-2020, 11:22 PM | #5 |
17
Rep 35
01-03-2020, 11:29 PM | #6 |
7281
Rep 7,457
I highly doubt he has his facts correct, the m2 uses a piston style pump not a rotary pump so it can't be over driven. I'm willing to be corrected, but it is unlikely since it would have been done by now if possible since overdriving units are way easier to make compared to larger cylinder volume piston style hpfp upgrades.
01-03-2020, 11:46 PM | #7 | |
17
Rep 35
http://spoolperformance.us/index.php?route=product/product&product_id=77 |
01-04-2020, 12:09 AM | #8 | |
756
Rep 2,149
I do agree Spool's lifetime warranty is better than XDI's 1yr warranty. Though Spool requires you to purchase a new pump before the warranty process is even started. Then after you send back the old pump, if the warranty is accepted, you will be reimbursed. |
01-04-2020, 12:41 AM | #9 | ||
7281
Rep 7,457
In regards to the warranty, I was not sure how the spool warranty worked but they did say no hassle guarantee on their page and to email them for warranty, I didn't know that you had to buy a pump first. Still better than a 1 year warranty that's for sure. So imo to make sure you do retain a warranty buy the filter, and use high quality fuel + fuel stabilizer if you are using ethanol to prevent moisture accumulation.
ZM22824.00 |
