01-02-2020, 11:55 AM | #1 |
Modder of everything I own
147
Rep 491
Chassis Stabilization Malfunction
This is caused by numerous different root causes as I have found over the years modding my '13 BMW 335i xDrive. This time I had my car on the lift to fix an issue with my heat shield over the exhaust and thought since I had it in the air I would change my right wishbone since I knew the bushing was getting bad. After changing it I lowered the car and took it out for a short drive to check it out and right after turning a corner I got the Chassis Stabilization Malfunction warning. I know I get this after disconnecting the battery, although I hadn't disconnected it this time, so I stopped and turned the car off to reset which works to clear it after disconnecting the battery but it came back and the steering felt really weird and sloppy. I put it back on the lift and checked everything and the only thing I found was that the right ball joint on the tie rod end was much looser than the left side so I ordered a new ball joint end. I'll report back after changing it out this weekend.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
01-02-2020, 05:19 PM | #2 |
4016
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
It's super easy to screw up your steering (requiring a new alignment) when changing one of the LCA/wishbones. Whenever I remove one of those I secure the steering wheel in place to prevent it from moving.
In the meantime you can try recalibrating the steering by moving the wheel from lock to lock 3-4 times each side.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
01-03-2020, 10:54 AM | #3 |
147
Rep 491
You are 100% right on that one as I discovered yesterday. I can see the wheels are out of alignment, I can't believe I missed that after installing the wishbone. I didn't think it could screw up the steering like that so I definitely learned something. Thank you for the info, that helps me immensely!!
05-03-2021, 05:52 PM | #4 | |
230
Rep 525
can you recall? i'm trying to figure out how to do just that, not sure how exactly to tie it around the steering wheel spokes. |
05-03-2021, 07:42 PM | #5 | |
4016
Rep 3,540
gippy230.00 |
