01-02-2020, 04:46 AM | #1 |
128
Rep 163
Drives: F31 M Sport, 6MT, Alpine White
delete
01-02-2020, 08:53 AM | #2 |
128
Rep 163
BUMP
01-02-2020, 10:46 AM | #3 |
128
Rep 163
BUMP 2
01-02-2020, 11:29 AM | #4 |
588
Rep 2,302
BUMP 3
No need to flash. You have to expand your VO/FA with 6WA. With the changed VO/FA first you should code the HU and then like your TRSVC you have to assign a CAFD and code the Kombi. From the retrofit guide i only would recommend to execute point "7 Write FA to the car". The other points are not necessary for you. |
01-02-2020, 12:34 PM | #5 | |
128
Rep 163
- HU_NBT - KOMBI and that should be it? What about BKOMBI? Can I leave it there or I need to remove it? |
01-02-2020, 12:47 PM | #6 | |
588
Rep 2,302
Then you can code the Kombi. |
01-02-2020, 12:54 PM | #7 | ||
128
Rep 163
01-02-2020, 01:03 PM | #8 |
588
Rep 2,302
01-02-2020, 01:07 PM | #9 | |
128
Rep 163
Which CAFD I need to assign, the newest available or?
01-02-2020, 01:08 PM | #10 |
588
Rep 2,302
01-03-2020, 07:11 AM | #11 | |
128
Rep 163
I have added 6WA, write FA/FP, Coded NBT, but I still only see BKOMBI?
01-03-2020, 07:54 AM | #12 | |
588
Rep 2,302
Please check this coding value in HU_NBT. EXTERNER_MOST = aktiv Then under Settings check if the 2 hooks are set (see attached picture). If not, so set the hooks and code again the HU_NBT. After that try both variants "Read SVT" and "Read Ecu". The MOST cable is connected correctly? Do you have ISTA and can check if there are errors or if the Kombi will be displayed? |
01-03-2020, 08:10 AM | #13 | ||
128
Rep 163
Went throu the same process as before and now I don't see neither BKOMBI or KOMBI. Before I had 15 ECU's in the SVT, now I have 14 MOST is connected well bcs I can see red light comming on the end of the cable.
01-03-2020, 11:21 AM | #14 | |
588
Rep 2,302
Many people already had this problem when retrofitting the 6WA. Did you try to "read ECU"? I think yes. You can try to let the car sleep for maybe 30min. and try it again. Do you have ISTA/Rheingold? |
01-03-2020, 11:54 AM | #15 | ||
128
Rep 163
I did try to swiching between "Read ECU" and "Read SVT" but nothing. I have one question. This 6WA cluster is from 07.2015 (LCI), what if I go to the FA List > FZAuftrag > Type > Zeitkriterium, and change it from 0712 to 0715? Will this myb help to apear KOMBI? Also, do I myb need to code FEM_Body?
01-03-2020, 12:10 PM | #16 | |
588
Rep 2,302
But you can try it anyway. You also can try to code the FEM, but it's the same - the Kombi should appear when you click "Read Ecu". Sometimes i also read about initialize the MOST ring, but i don't know how to do this. I think you need ISTA for checking some things. |
01-04-2020, 07:36 AM | #17 |
12
Rep 56
Hi,
I have BKOMBI and want to retrofit 6WA KOMBI. My car is F31 with HU_ENTRYNAV, w/o HUD, VIN: K307402. First step is to buy the cluster. What part number should I look for? |
01-04-2020, 10:31 AM | #18 | |
588
Rep 2,302
Second step to buy the cluster Possible part numbers... 62109382106 62106804976 62106834507 62106843144 62106847247 62108803210 62109436307 |
chr12.00 |
01-04-2020, 02:04 PM | #19 |
12
Rep 56
Thank you!
I checked with ISTA and it show that KOMBI and HU are connected by MOST. Is this enough, or I have to go further, like disassemble existing cluster and see what kind of connectors it has. |
01-05-2020, 03:23 AM | #21 |
12
Rep 56
If I get a virginized cluster, I understand no need for flashing.
Is it ok to only follow the steps from post #8? Can I do this with engine running, so no need for power supply? |
01-05-2020, 03:29 AM | #22 | |
588
Rep 2,302
The steps from post #8 should work. And you need no power supply because it‘s only coding. You can do it with engine running. |
chr12.00 |
