12-31-2019, 09:40 PM | #1 |
Rep 3
Who has run a cable through the firewall?
(2016 f48 X1, LHD) Seeking some advice from anyone who's routed a cable through the firewall. I'm installing an amplifier and need to run the 12v+ from the battery through the firewall and I'm not sure where to find a good spot.
Can someone point me in the right direction? Thanks |
01-01-2020, 01:06 AM | #2 |
80
Rep 241
There's a hole in the firewall behind the battery near the steering column region covered with a rubber plug. You can access this hole by lifting the hood up, and looking into the top right corner of the hood area and down an opening. There's a rubber plug that can be removed and you can run wires through there.
MtnHank10.50 Rex_Banner0.00 |
01-04-2020, 03:18 AM | #5 |
80
Rep 241
04-22-2020, 01:07 AM | #7 |
80
Rep 241
11-14-2023, 04:46 PM | #8 |
185
Rep 600
Drives: 2018 F48 X1 xDrive 18D
Does someone have a picture of this
11-28-2023, 04:18 PM | #9 |
Rep 61
RHD. The plug literally shines through if view from the glove compartment fuse box area.
11-28-2023, 04:58 PM | #10 |
185
Rep 600
LHD and that one is taken
But found a way (LHD) Driver side red Passenger side green Driver side was predrilled hole in firewall material also, passenger side I had to pike through the firewall material |
