12-31-2019, 02:41 AM | #1 |
Rep 6
AC automatically on issue
hello guys,
I realized the AC will be turn on after switch to inner loop, is that possible to disable that function by coding? my target is AC keep off anytime unless turn on manually. |
12-31-2019, 07:18 AM | #2 |
8243
Rep 16,082
Expecting snow?
My advice is to put it on auto and forget about it. Just because the light is on doesn't mean the compressor is engaged. It just shows that its true function, climate control, is working. |
12-31-2019, 08:24 AM | #3 |
2465
Rep 5,457
Drives: F30
I was in the same boat as you... coded with BimmerCode. Now I am able to manually decide if I want AC on or off.
01-01-2020, 08:03 PM | #4 |
Rep 6
really? I mean the AC button on doesn't mean the compressor was started? is that the BMW feature? thanks
01-01-2020, 09:36 PM | #5 |
8243
Rep 16,082
The compressor comes on when temperature and/or humidity conditions require it. Otherwise it's off. That's not a BMW exclusive. I have mine set on auto, at 68F, year round, and I do get snow, sometimes six months out of twelve. When the weather is hot the compressor kicks in and the climate control system cools. When the weather is cold the climate control system heats. What BMW should change is the button that says AC. It should say 'Climate Control', because that's what it does.
01-02-2020, 03:51 AM | #6 | |
Rep 6
