12-29-2019, 07:28 PM | #1 |
Remove Before Flight
6869
Rep 1,614
Ok-- my head exploded. A little tire/spacer fitment help?
I've been reading here for *hours* in preparation for a "My car's on order" parts binge and am now more confused than ever.
Hopefully, this'll be an easy question: 2020 M2C with *stock* suspension (NO plans to lower, go coilovers, etc). Will 10MM front & rear spacers combined with (F) 255/35/19 and (R) 275/35/19 fit with NO ISSUES? i.e. no rubbing on the body, plastic shields or strut? (Not even a little bit). I'm looking at going +1 (eventually) on the front/rear tires, and am thinking about picking up IDS's "Essential" kit (front/rear reflector delete, wheel spacers, and bolts). If this is a poor setup, then I won't waste the money on the spacers. Conversely, am I better off just going 255/275 with NO spacers? From what I've read, the 255/275 is a "safe" fitment of tires? I +1'd (245/275) my old e46 M3 and really liked the handling-- and when I test drove the M2C, it was a bit more tail-happy than I'd like, so I'm thinking a bit more rubber might not go amiss. Normally, I'd wait and drive it a while, but I need to get the reflector delete sorted before delivery so I can paint correct, ceramic coat and PPF as soon as the car's delivered. Which makes a difference on the IDS stuff. TIA-- R. |
12-29-2019, 09:05 PM | #2 | |
this is the way
18306
Rep 8,544
flybigjet6868.50 |
12-29-2019, 09:26 PM | #3 | |
758
Rep 1,337
https://www.turnermotorsport.com/p-3...7-m2/?pdk=AgQC
Previous Rides: 13' 135i, 08' 130i, 03' HKS Turbo'd 350z, Modded GC8 WRX, NA MX5
12-29-2019, 09:41 PM | #4 |
6869
Rep 1,614
Whoops. Sorry.
IND, yes. IDS is my PPF go-to and I had them on the brain. So, it appears that the best answer is just to go with the 255/275 combo and call it a day. I do NOT want the tire to stick past the rim. Maybe I'll order some PS4S's in those sizes and sell the stock rubber as a "take-off" when the car comes in. Assuming there's a market for brand-new take off 245/265's. Thanks guys-- R. |
12-29-2019, 10:17 PM | #5 | |
this is the way
18306
Rep 8,544
12-30-2019, 01:06 AM | #6 |
280
Rep 391
Drives: F87 M2C
I think I've seen people go with 10mm in front and still be fine which is surprising.
Going 255/35 seems to be fine, I've seen someone on here do it But both? Definitely not. I took a look at the stock clearance on mine and man is it close and full lock. It's like this on both sides.
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
