12-28-2019, 11:28 AM | #1 |
30
Rep 131
Another Tire size question - Ratios
I'm switching over to 295 in the rear and 265 in the front, but I notice that some people put 295/40/21 - and others put 295/35/21 in the rear. Seems like everyone keeps it 265/40/21 in the front.
With the 295/35/21 in the rear and 265/40/21 in the front: 1. Won't you notice a lower profile tire in the rear and not in the front? 2. Won't the shorter tires technically revolve faster and will it mess up the all-wheel-drive? Thanks! |
12-28-2019, 11:34 AM | #2 |
The Hammock Man
493
Rep 593
Drives: X3MC, X3 M40i, E93 M3
I’m doing the same, 265/40/21, 295/35/21. Less than 1% diff from stock ratio... won’t negatively effect anything (other than slightly heavier tires (may lose .1 sec in drag times), but will improve grip and vastly improve the vehicles’s look/stance, especially in the rear.
- '20 X3MC | Alpine White | Black Alcantara/Midrand Beige | loaded | 295/265 PS4S - '09 E93 M3 | Alpine White | Bamboo Beige Novillo | DCT | loaded | Chrome M220 Wheels - 275/255 PSS |
12-28-2019, 11:40 AM | #3 | |
216
Rep 296
Drives: M3 Competition (G80)
A 305/35 on the rear would be the closest match for height and diameter, but think it would be to wide. Add on a spacer and I might need an industrial mud flap. Interested to see what others are doing. |
12-28-2019, 11:43 AM | #4 | |
30
Rep 131
12-28-2019, 11:47 AM | #5 | |
30
Rep 131
12-28-2019, 12:08 PM | #6 | |
1305
Rep 1,221
Max Well4736.00 |
12-28-2019, 12:10 PM | #7 | ||
30
Rep 131
12-28-2019, 12:11 PM | #8 | |
62
Rep 132
My question is how a wheel with a stock, straight from the factory 265 could take on a 295 tyre. Isn't the tyre way to big? |
12-28-2019, 12:19 PM | #9 |
The Hammock Man
493
Rep 593
295 is the largest/widest to fit on the stock wheel.
(For reference, the M40i has a .5” more narrow wheel, but stock 275’s. No problem getting a 295/35/21 on the X3MC 10" rim... 265f/295r SHOULD be the stock option on the X3MC!!)
- '20 X3MC | Alpine White | Black Alcantara/Midrand Beige | loaded | 295/265 PS4S - '09 E93 M3 | Alpine White | Bamboo Beige Novillo | DCT | loaded | Chrome M220 Wheels - 275/255 PSS Last edited by SWOT1; 12-28-2019 at 02:25 PM.. |
12-28-2019, 12:35 PM | #10 |
1305
Rep 1,221
The variability really depends on the factory rim/tire combo. In our case, the rear tire width (265) is quite conservative given the width of our rear rims. When viewed vertically, they probably curve slightly inwards meaning they're more on the minimum end of the tire width that could be mounted. A full vertical nuetral width might be around 275 or 285. 295 will probably be wider than the metal rim (someone who's tried this can correct me if I'm wrong),so it won't be a 90 degree vertical rise from rim to edge of tire but will still be within the limits of what can be properly fitted on that rim.
Thewolfbmw215.50 |
12-28-2019, 01:40 PM | #11 | ||
4998
Rep 6,863
For example, the rear 265/40/21 tires on the X3M have a measured rim width of 9.5" but will fit on a wheel between 9.0-10.5" wide. I believe the X3M wheels are 10" wide which is in the 265/40/21 tire fit range, albeit slightly stretched from the 9.5" measured rim width. The 295/35/21 tire has a measured rim width of 10.5" but will fit on a wheel 10-11.5" wide. So the factory 10" wide wheel is within its range, however it is the minimum width needed to safely run that size tire. |
Thewolfbmw215.50 |
12-28-2019, 02:20 PM | #12 | |
62
Rep 132
Thewolfbmw215.50 |
12-28-2019, 02:22 PM | #13 | |
62
Rep 132
Thewolfbmw215.50 |
12-29-2019, 08:10 AM | #15 | |
4998
Rep 6,863
A 20" wheel setup should ride noticeably more comfortable than a 22" wheel setup. |
12-29-2019, 09:44 AM | #16 | |
dunny
128
Rep 260
12-29-2019, 09:48 AM | #17 |
The Hammock Man
493
Rep 593
Can't wait to post plenty of pics! Vehicle should be built/delivered by the end of January.
12-29-2019, 11:48 AM | #18 |
30
Rep 131
Ok so here's another question. I havent even looked to see what size the spare is, but lets say I switch over to 265's and 295's and I get a flat tire - can I still put that spare on???
12-29-2019, 12:00 PM | #21 |
The Hammock Man
493
Rep 593
Mobility kit deletes the spare. (I need the extra cargo space, and not the extra weight for the spare.)
