12-28-2019, 10:36 AM | #1 |
Rep 6
Clear Airbag Light error - F30 - 320d
Hi all,
a few days ago i changed the speed LIM button on my bmw F30, for that I had to remove the airbag from the steering wheel...and replace everything...the new button is working well. I tested all the other buttons and the horn, all working well....BUT, now, i have an Airbag error signal on the panel instrument. My question is : can i clear this error using Esys ? if yes, someone have any tutorial ? if no, which software should i use ? any tutorial/downlaod ? Thanks for your help. |
12-28-2019, 10:53 AM | #2 |
8243
Rep 16,082
You need to use ISTA or an OBD diagnostic and repair tool. It should not have thrown an error if you disconnected the battery negative terminal before removing the air bag.
12-28-2019, 11:39 AM | #4 |
588
Rep 2,302
You can try to delete the errors with E-Sys by this way.
On the left side External Applications -> External Application -> Doubleclick Transmitter. And then Clear DTC -> Connect -> Send and InfoSpeicherLöschen -> Connect -> Send |
BMW DIY Guy3074.00 |
02-22-2020, 04:33 PM | #6 |
3074
Rep 3,022
Drives: 2019 M2 Competition
Good to know!
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
