12-22-2019, 07:03 PM | #1 |
117
Rep 51
New Wheels Questions
I wanna get some new wheels for my X3M Comp. I wanna stick with the 21.9 and 21x10 size
What's the best offset to get a flush look without having to use spacers? (front and rear?) Who is making wheels for the X3M Comp? If I find a good looking wheel, I'd be fine with using spacers If I had too.(12mm-15mm) Looking for a gloss black finish as well. Thanks for your help. Last edited by bulwhip; 12-26-2019 at 08:20 PM.. Reason: link |
12-22-2019, 07:17 PM | #2 |
12971
Rep 18,717
I should be able to get you a set from Forgestar.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... Last edited by r33_RGSport; 12-22-2019 at 07:38 PM.. |
12-22-2019, 07:39 PM | #4 | |
12971
Rep 18,717
That G05 X5 wheels, they didn't list the offset. If you can find out the offset, I can check if it will fit or not.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
12-22-2019, 08:01 PM | #5 | |
117
Rep 51
I need lowering springs too |
12-22-2019, 08:19 PM | #6 | ||
12971
Rep 18,717
Should be soon. I believe any FS style are available. I got your PM, I'll check tomorrow.
12-22-2019, 08:23 PM | #7 |
117
Rep 51
r33_RGSport12971.00 |
04-03-2020, 08:47 AM | #10 |
Rep 20
04-03-2020, 09:29 AM | #11 | |
12971
Rep 18,717
PM me which style and finish that you wanted, and I'll give you a quote.
04-03-2020, 09:42 AM | #12 |
Rep 20
04-03-2020, 10:15 AM | #13 | |
396
Rep 525
Perfect fitment (no spacers, second ET is with 12mm spacers) Fronts: 21 x 9.0 ET13 ET25 21 x 9.5 ET19 ET31 Rears: 20 x 10 ET27 ET39 20 x 10.5 ET33 ET45 20 x 11 ET39 ET51 Shy of custom/semi-custom brands, you might want to consider using a spacer with a higher offset rim, particularly if cost is an issue. I hope this helps. Also, watch the concavity. Apparently a lot of the "super deep" designs have issues with clearing the brakes. Deep designs are usually fine, except on the fronts. |
