12-22-2019, 08:02 AM | #1 |
178
Rep 374
Removing Vehicle From ConnectedDrive Account
Has anyone removed a vehicle from your ConnectedDrive account and added it back successfully?
Did the process go smooth? Were all of your subscribed services still there? Thanks |
12-22-2019, 12:31 PM | #2 |
91
Rep 233
12-22-2019, 02:04 PM | #3 |
17
Rep 102
12-22-2019, 02:43 PM | #4 | |
178
Rep 374
I removed my X3 from the account. Then went back in an clicked "Add New Vehicle". Put in the VIN Went to the car to retrieve the code that was sent. Everything worked as it should. All my subscriptions are in there with the added bonus of Car Play until the year 2038. The only this that does not work is the ConnectedDrive Store access from the vehicle. I can only access that from my PC. This was a problem before I removed and re-added the X3. |
12-22-2019, 06:53 PM | #5 | |
17
Rep 102
12-22-2019, 08:35 PM | #6 |
41
Rep 155
Member Kevin Kay advised he could Add it back in via his cell phone but not via his laptop. So I tried using my cell, instead of my laptop, and it added it back in perfectly! The Connected Drive lady had advised me there is no way to add it back in unless you do it in connection with the dealer and re-executing the ESA. I see now that was not correct. Using the cell to add it back worked.
12-23-2019, 06:40 PM | #7 | |
683
Rep 1,123
12-24-2019, 07:49 PM | #9 |
1463
Rep 3,936
12-24-2019, 08:39 PM | #10 |
178
Rep 374
12-24-2019, 09:00 PM | #11 |
10
Rep 38
I have done it. It is is only why I thought one could change your number plate / nickname (I was wrong). But you can delete and add multiples times.
12-26-2019, 07:17 PM | #13 |
1463
Rep 3,936
