2Addicts
2Addicts
2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Wheels and Tires ► APEX | Flow Formed Lightweight BMW Wheels - Built to Perform
      12-17-2019, 04:58 PM   #1
ApexWheels
ApexWheels's Avatar
1421
Drives: M3
Apex Flow Formed Wheels for BMW F22 F23 2 series | Built to Perform
For over 10 years, Apex has been the go-to wheel for BMW enthusiasts looking for the perfect balance between strength, weight, and cost. Our ARC-8 and EC-7 designs address the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. Our newer FL-5 and SM-10 designs provide a step-up in strength and true race wheel features like I-beam spokes and reinforced lips.
➡︎ Perfect fit without spacers
➡︎ Made to work with big brake kits
➡︎ 100% OEM compatibility, no extra hardware required
➡︎ Unbeatable warranty & 50% replacement program
Order Now
ARC-8 / EC-7 / FL-5 / SM-10
Designs & Finishes
ARC-8 - 17" / 18" / 19"
The lightest flow formed wheel we make. Also the most affordable. A deep lug recess allows for easy access for beefy impact sockets without scratching the wheel face. Available in Profile 1 (less concavity) and Profile 3 (deep concavity). The less concave profile provides increased caliper clearance on narrow applications, while the deep concave profile reduces weight and creates a stunningly aggressive appearance on low offset and wide width applications. Both profiles are available in 17”, 18”, and 19” diameters. Face profile is determined by offset and width and cannot be selected independently.
EC-7 - 18" / 19"
Massive brake clearance & a plethora of fitments. The curved spokes of the EC-7’s face beautifully contour around some of the largest brake calipers available. The split "Y" spokes were carefully evaluated from every aspect to ensure light weight and remarkable strength. Available in Profile 1 (less concavity), Profile 2 (medium concavity), and Profile 3 (deep concavity). Profile 1 provides increased caliper clearance on narrow applications, while the deepest concave face reduces weight and creates a stunningly aggressive appearance on low offset and wide-width applications. All three profiles are available in both 18”, and 19” diameters. Face profile is determined by offset and width and cannot be selected independently.
FL-5 - 18"
Gorgeous flow formed lip with I-beam spokes for reduced weight. Both the inner and outer lips are flow formed to stand up to all the abuse the street and track have to offer. The spokes of the FL-5 were designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. It’s expensive and avoided by almost every manufacturer, but affordable with volume. Available in Shallow, Medium, and Deep lip profiles. This maximizes spoke concavity and reduces weight on the FL-5 design. Lip size is determined by offset and width, and cannot be selected independently.
SM-10 - 18" / 19"
Modern design with reinforced lips and I-beam spokes. Like the FL-5, the SM-10 spokes were also designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. Available in Profile 2 (medium concavity) and Profile 3 (deep concavity). The medium concavity is offered on narrow-width applications, while the deep concavity is offered on our wide-width applications. Concavity is dependent on width and offset, and cannot selected independently.
Order Now
Fit Matters
The right solution for every application. An optimized car setup begins with the perfect wheel and tire fitment. Without model-specific attention to each wheels specifications, maximum performance is compromised. Each size was selected to find the right balance between a clean fit and the most grip possible. Each design's wide range of widths, offsets, and face profiles result in unique fitments ranging from 8.5" to 11" wide. Each wheel combines these features to meet the different brake caliper, strut, and fender clearance needs of each BMW model. Most vehicle models have options for wheels that range from direct-fit to aggressive for specialty applications. Daily drivers and professional racers don't have the same needs, so why should they be forced to buy the same exact fitment?
100% OEM Compatibility
No need to change your wheel bolts, center caps, or TPMS sensors. All Apex BMW wheels were designed from the start to work with OEM 60º tapered hardware, which means both OEM lug bolts and aftermarket stud kits with the proper lug nut seat type will fit perfectly. All of our 5x120 BMW wheels use a 72.56mm center bore, no hubcentric rings or adapters are necessary. All wheels come with gloss black Apex center caps, but you can also snap-in your OEM BMW caps for a more OEM+ look. All Apex wheels accept OEM and aftermarket equivalent TPMS sensors, and any standard-sized metal or rubber valve stem.
Brake Clearance
If the spokes or barrel of a wheel can’t clear your brakes, the wheel can’t be used at all. We’ve made sure all of our flow formed wheels clear OEM steel brakes spacer-free when the correct vehicle-specific designs and fitments are used. With many applications, even big brake kits will clear spacer-free. The 17" ARC-8 clears many kits up to 355mm. Our 18" wheels clear up to 380mm, including some variants of the Brembo GT kit, which has long been the benchmark as one of the toughest brake setups to clear. Our 19" wheels clear even the 410mm BMW Carbon Ceramic brakes. View our fitment guides to confirm brake clearance, or contact us if you don't see your setup listed.
Weight Optimized
We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a flow formed wheel with an ideal balance of strength and weight.
True VIA - JWL & Beyond
Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. Apex flow formed wheels are officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our wheels exceed those ratings. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy.
Learn more about VIA and JWL
Additional Features
Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required.
Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps.
Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Lifetime Warranty
All our wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase.
Apex Wheel Replacement Program
Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our unique Apex Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices.
Chassis-Specific Fitment Guides
We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides.
Apex BMW Wheel Gallery
Order Now
Questions?
Call: 925-245-0773
Email: expert@apexwheels.com
Web: www.apexwheels.com
Hours: M-F 9a-5p PST
      12-17-2019, 04:59 PM   #2
ApexWheels
ApexWheels's Avatar
1421
Drives: M3
      06-01-2020, 04:07 PM   #3
Expert@ApexWheels
Expert@ApexWheels's Avatar
3510
Drives: M3
Strong and Light:
The I-beam spokes of the FL-5 and SM-10 reduce the rotational mass of these designs while also being visually striking.
Pick up your set today!
      07-30-2020, 08:41 PM   #4
Anubis80
49
Drives: 2018 f80 YMB zcp
Originally Posted by Expert@ApexRaceParts View Post
APEX Overstock Sale
Too much of a good thing!
Some of our wheels have been idling on our shelves for too long! In order to make more room for exciting fresh inventory, we've decided to put select wheels on sale! This will be an ongoing sale and the products will be updated every 2 weeks depending on inventory. Don't see the offset or width that you are after? Check back in a few weeks! You never know what might go on sale!
Head over to our website to check out the sale now!
If only ec-7 in black!!!
      08-31-2020, 06:33 PM   #5
Expert@ApexWheels
3510
Drives: M3
APEX Overstock Sale
      11-06-2020, 02:51 PM   #6
Expert@ApexWheels
3510
Drives: M3
The Flow Formed ARC-8 is our lightest, most affordable flow formed wheel, which is why it’s been our best seller for over 10 years. Part of our Classic line, it's a timeless motorsport design engineered to optimize weight and strength.
      12-07-2020, 04:05 PM   #7
Expert@ApexWheels
3510
Drives: M3
The Flow Formed SM-10 and FL-5 feature I-Beam spokes to reduce weight without sacrificing strength.
      01-05-2021, 11:46 AM   #8
Expert@ApexWheels
3510
Drives: M3
The Flow Formed APEX EC-7
Available in Matte Bronze Finish in select sizes
      01-21-2021, 05:13 PM   #9
Expert@ApexWheels
3510
Drives: M3
The Flow Formed APEX FL-5
The FL-5 is our only wheel to feature dual flow forming. Both the barrel and front outer lip are formed using high-pressure rollers to maximize strength while simultaneously reducing weight.
      02-04-2021, 05:20 PM   #10
Expert@ApexWheels
3510
Drives: M3
Hyper Black Finish
The Hyper Black finish, only available on our Flow Formed ARC-8 model, is a great alternative to Hyper Silver. Featuring a darker inner barrel and shadow chrome like appearance, it's sure to give your BMW a stylish yet aggressive look.
      03-09-2021, 05:02 PM   #11
Expert@ApexWheels
3510
Drives: M3
Finishing Touches
APEX wheels are finished using a multi-stage liquid paint over a powder coated base coat. This coating process leaves lug holes, center bores and mounting pads untouched, which ensures proper fit and torque values.
      04-06-2021, 05:35 PM   #12
Expert@ApexWheels
3510
Drives: M3
The Flow Formed FL-5
The FL-5 was designed with a focus on maintaining optimum brake clearance without sacrificing the deep dish appearance. The spokes feature a curved design made to easily clear most aftermarket calipers.
      05-19-2021, 04:34 PM   #13
Expert@ApexWheels
3510
Drives: M3
The Flow Formed EC-7: Born To Clear Massive Brakes
Through comprehensive laser scanning and endless rounds of test-fitting, the EC-7 was created to clear massive brake kits. Offered in three unique profile designs, the Flow Formed EC-7 offers maximum concavity without sacrificing clearance.
      07-06-2021, 05:41 PM   #14
Expert@ApexWheels
3510
Drives: M3
E92 M3 on 18" APEX ARC-8 Wheels in Satin Black Finish
F/R: 18x10" ET25 ARC-8s in Satin Black with 295/30-18 Toyo R888 tires
7mm spacers at all four corners
      08-06-2021, 06:49 PM   #15
Expert@ApexWheels
3510
Drives: M3
F82 M4 on 19" APEX SM-10 Wheels in Satin Black Finish
F: 19x9" ET30 with 265/35-19 Sport Cup 2 tires and a 16mm spacer
R: 19x11" ET44 SM-10 with 305/30-19 Sport Cup 2s and a 5mm spacer
      10-07-2021, 02:47 PM   #16
Expert@ApexWheels
3510
Drives: M3
Chassis Specific Fitments
We’ve tirelessly test-fitted hundreds of setup combinations in order to provide direct-fit, spacer-free, and hub centric wheel packages for everything from showroom-fresh cars to all-out race builds. All APEX wheels are made to work perfectly with your OEM hardware and BMW roundel center caps.
F: 18x8.5" ET35 with 235/40-18 tires
R: 18x10.5" ET22 with 275/35-18 tires
      11-19-2021, 06:44 PM   #17
Expert@ApexWheels
3510
Drives: M3
F87 M2 Competition on Flow Formed 19" APEX EC-7 Wheels in Race Silver finish
F: 19x9.5" ET28 with 265/30-19
R: 19x10.5" ET45 with 295/30-19
Tires: Toyo R888
      12-08-2021, 01:35 PM   #18
Expert@ApexWheels
3510
Drives: M3
Paging BMW owners in the Bay area!
If you're interested in free professional photos of your car on brand new APEX wheels, we are looking for volunteers for testfiitting and photoshoots! Volunteers will get copies of the photos, a discount on a set of APEX wheels, and APEX goodies/swag. If you're interested in volunteering, please email us at info@apexraceparts.com with your contact information, location, and a photo of your car. All are welcome. Show us what you've got!
If you'd like to take an inside look at what these photoshoots involve, our good friend Blake made a video detailing the process of an 18" test fitment on his F82 M4 recently:
      12-17-2021, 05:31 PM   #19
Expert@ApexWheels
3510
Drives: M3
In stock and Ready to Ship!
Our production team has been hard at work this year getting our shelves stacked high with inventory for the Holiday season. In stock Flow Formed fitments for all 5x120mm BMW chassis are available. Checkout our site and order your set today!
F/R: 18x10" ET25 w/ 285/30-18 RE-7rR tires
Added negative camber front/rear
      01-13-2022, 02:30 PM   #20
Expert@ApexWheels
3510
Drives: M3
BMW F82 M4 with 19" SM-10 Wheels in Anthracite
The Flow Formed SM-10 packs high end features typically found only on Forged wheels. Knurled beading, a tough inner lip, I beam spokes and impressive brake clearance make the SM-10 an unparalleled value. Most fitments are in stock and ready to ship today!
F: 19x10 ET25 w/ 275/30-19
R: 19x11" ET44 w/305/30-19
Tires: Michelin PS4S
      02-10-2022, 12:08 PM   #21
Expert@ApexWheels
3510
Drives: M3
It's Group Buy Season!
Don't miss out on your chance to save big on 17" ARC-8s, 18" ARC-8 and EC-7, and 19" SM-10 BMW fitments. Hit the link below to learn more:
Click Here to Join
Specs:
Front - 18x9.5" ET22 and 275/35-18 tires
Rear - 18x11" ET44 with 305/35-18 tires
Tires - Nitto NT01
      06-06-2022, 06:04 PM   #22
Expert@ApexWheels
3510
Drives: M3
We have a limited supply of specific tire sizes in stock and ready to ship! If you are interested in any of the tire options listed below, please email expert@apexraceparts.com with “Tire Discount” as part of the email subject. We can provide additional discounts on wheel and tire packages with these tire sizes or in some cases we can make a one-time exception to our standard ordering rules and ship tires without wheels! Please reach out for package and shipping quotes if you’re interested.
Nitto NT01 235/40-17
Nitto NT01 255/40-17
We are not able to order any tires that are currently out of stock on our website. This offer does not apply to tire fitments outside of the above list.
JRZ Kit Blowout sale!
We have JRZ Suspension packages on sale, in stock, and ready to ship at stellar pricing for a handful of BMW chassis. This is an awesome chance to upgrade your suspension and dramatically improve the performance of your BMW, while avoiding the typical long lead times.
Our entire inventory is shown below. All kits are in stock and on sale anywhere from $400 to $600 off:
BMW E36 - 1 left in stock!
JRZ RS TWO
Double Adjustable
BMW E46 - 1 left in stock!
JRZ RS PRO
Double Adjustable Remote Reservoir
BMW E9X 3 Series - 1 left in stock!
JRZ RS ONE
Single Adjustable
BMW E8X 1 Series - 1 left in stock!
JRZ RS ONE
Single Adjustable
BMW F3X 3 & 4 Series - 1 left in stock!
JRZ RS TWO
Double Adjustable
BMW F22 2 Series- 1 left in stock!
JRZ RS TWO
Double Adjustable
If you're interested in purchasing a set, send in an email to expert@apexraceparts.com to get in touch or configure your kit on our suspension page.
Search this Thread:
Advanced Search
2addicts
