11-25-2019, 02:52 PM | #1 |
M340i
393
Rep 968
Drives: BMW M340i
Can I code out double door pull?
Is there a way to code out having to double pump the interior door handle to open the door? If so can someone point me to the steps? Also I would love to have the ac not turn on each time I start the car.
11-25-2019, 04:31 PM | #2 | |
21
Rep 87
As soon as you switch off the ignition doors will open And have air conditioning/ heater remember last state |
11-26-2019, 05:15 AM | #3 |
31
Rep 59
Yup. I did this trick in BimmerCode and it works perfectly. Now if I could get easy seat access to work again I would be set.
11-26-2019, 04:06 PM | #4 |
M340i
393
Rep 968
Drives: BMW M340i
Yes. I have bimmercode. I couldn’t figure out where it was. I’ll check the suggestions. Thanks guys.
11-26-2019, 04:43 PM | #5 | ||
2963
Rep 5,997
11-27-2019, 01:20 AM | #6 |
238
Rep 878
I’ve also coded mine to unlock all the doors when I stop the engine. I think after coding it puts an option in idrive so you can enable/disable it from there.
