18" Staggared Winter/Snow Tire Setup?
08-29-2008, 09:40 AM | #1 |
Tax Paying, Gun Toting American Veteran
13
Rep 249
With winter shortly arriving, I have been looking at getting my snow tires. I have searched all the major tire manufacturers, but can not seem to get the sizes needed. I want to keep the same tire sizes as stock, 225/40 18 front and 255/35 18 rears. Has anyone found a setup that works? Either Runflat or not?
I'm Winston Wolf, I solve problems...
08-29-2008, 09:53 AM | #2 | |
111
Rep 1,764
Orb |
08-29-2008, 11:49 AM | #3 |
Bootleggin' 'n Gunrunnin'
137
Rep 2,372
Which happen to be runflats in the 225/40-18 and 255/35-18 sizes. Also, the Blizzak LM-25 is avaibable in 225/40-18 and 255/35-18 sizes, but are not runflats. Both options at Tire Rack....
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
08-29-2008, 01:26 PM | #4 |
41
Rep 1,300
Tyre-Fabrikation: Hankook
Typ: W300 XL ReifenDimension front: 225/40 R18 92V ReifenDimension rear : 255/35 R18 94V thats what i can tell you
Freude ist BMW
E91 SG LCI m-sport,E88 AW m-sport |
08-30-2008, 12:10 AM | #5 | |
111
Rep 1,764
Orb |
08-30-2008, 12:12 AM | #6 |
3187
Rep 10,509
OP you get better snow traction with narrower tires. I think you should go with 225 width all around. You'll also potentially keep your tire cost down since you'll be able to rotate the tires
08-30-2008, 08:46 AM | #7 | |
111
Rep 1,764
Orb |
08-30-2008, 10:31 AM | #8 | |
53
Rep 1,162
Narrower tires = Better Traction??
I'd be interested in seeing some data.
Colonel (Retired), US Army/Hagerstown, MD
2016 518ixdrive/MSport AW/Ivory White ED-01-10 2010 Z4s30i AW/Beige/Burl/ 6MT/SP/PP/CWP/NAV/ipod/USB/CA (retired) 2011 335d BS/Oyster/PP/CWP/NAV/ipod/USB(Daily Driver) 30+ mpg(retired) |
08-30-2008, 11:49 AM | #9 |
152
Rep 3,983
08-30-2008, 01:01 PM | #10 | |
111
Rep 1,764
Orb |
08-30-2008, 01:19 PM | #11 | |
3187
Rep 10,509
Unfortunately, I don't know enough about tire tread design to discuss the underlying physics in detail with you. My understanding from shopping for tires while living in Canada is that the narrower tire focuses the vehicle's weight on a smaller area, allowing the tread to perform this evacuation of snow/slush more efficiently (ie if the tread design and vehicle weight are held constant, the narrow tire will evacuate the snow/slush more efficiently. I am having a hard time finding an online resource that outlines the physics in more detail. If this phenomena is incorrect, as you are suggesting, it is certainly very well propagated (links below) On my old cars (integra, focus) I've tried both 185 width and 195 width tire of the same type and the 185 tire did 'feel' like it gave more traction http://www.tirerack.com/winter/tech/...jsp?techid=126 "A wide, low profile or large tire has to "plow" a wide path through snow which causes more resistance. The narrower the tire, the easier you can get through snow." I did a quick search on the internet and many other reputable sites are posting similar advice http://www.canadiandriver.com/winter...nter_tires.htm "How can a narrower tire improve road grip? The rule of thumb from experts is that a narrower tire will cut through rain, snow and slush and bear down on the road better than a wider tire, which will tend to float up and over, losing grip in the process." http://editorial.autos.msn.com/artic...umentid=434745 "Contrary to conventional thinking for dry pavement conditions, on snow and ice narrower tires tend to provide better traction" |
08-30-2008, 02:10 PM | #12 |
313
Rep 2,576
The narrower tire concept is true, but only for driving through fresh snow. The narrower tire does not get as much resistance. However for driving on packed snow and ice the goal is to get as much siped surface area as you can. The more surface area of traction you have the better. Since most of the time in areas that receive snow you are actually driving on packed snow and ice, do not worry about the 255 width in the rear as it will help you, and since the fronts are doing the cutting in the fresh snow, I don't think the added width in the rear will make much difference at all, other than providing you with more traction on the packed snow and ice surface.
08-30-2008, 05:26 PM | #13 | |
111
Rep 1,764
http://hyperphysics.phy-astr.gsu.edu/hbase/frict3.html Orb |
08-30-2008, 05:42 PM | #14 |
313
Rep 2,576
Orb that link does not take into consideration the force that unpacked snow applies to the tires in front of the tire as the tire "plows" through snow. This is why a narrower tire actually does perform better in deep unplowed snow. This is also why you see those mud bog tractors with really narrow tires. However, on packed snow and ice, Orb is 100% correct. I have tried this first hand and the reality is the more surface area you can distribute across the surface will result in more traction.
08-30-2008, 08:11 PM | #15 | |
111
Rep 1,764
Things that do change are the normal force when you accelerate, brake or turn a corner. Friction is the key thing here as it changes drastically with changes to the normal force. You might be making the assumption that pressure changes a lot. The equation is (Pressure = Normal Force/Area) so if 265/30 x19 tire had 10 mm wide contact patch and 900 lb load on the tire the then pressure would be (219 PSI = 900 lbf /4.106 in^2) and same condition for a 225/30 x19 would be (259 PSI = 900 lbf / 3.487 in^2). Do you think the pressure will make a big difference? Both wide and narrow tires can provide good traction but it based on the tire design and has everything to do with the friction. The components of the friction created by the tire are its compound and mechanical features. If you have a tire that is to narrow and the normal force get to high (from acceleration) you can rapidly lose friction so you have very little traction…guess why your tires spin in the dry, wet or snow. A similar argument can be made for tires that are two wide. It all a balance and it comes down to the tire design in the end. Orb Last edited by Orb; 08-30-2008 at 09:26 PM.. |
08-30-2008, 09:40 PM | #16 |
313
Rep 2,576
Actually Orb my understanding of basic physics is pretty well based in my education - I am a licensed architect. That aside, I guess I missed the boat on how resistance will not have an impact on traction.
What you are not seeing is that snow can produce a load on the object that is passing through it. This load can vary based upon the water content of the snow. This is why it is very easy to drive through very light snow and then with the exact same car driving through heavy wet snow - not so easy. Everything you are stating above is assuming a static situation where the traction is based upon the contact patch only. In fresh snow you are dealing with more than the contact patch. If you think that resitance has nothing to do with traction, try driving your car across a frozen lake at speed with a 40 mph cross wind. I have done this in Maine. Trust me that force has a lot more to do with your traction than you realize. If you read my post you will see that I agree with the concept that wider tires in packed snow and ice do work better. In deep snow, you are 100% incorrect. As I have stated I see this every year and have tried many different setups. I actuall go for a wider winter setup now because most of the time I am driving on packed snow and ice. If it were always fresh snow, a) I would have narrow tires & b) I would be one happy mofo during ski season. Last edited by Nikolas; 08-30-2008 at 10:29 PM.. |
08-30-2008, 10:33 PM | #17 |
137
Rep 2,372
In the grand scheme of things though, for the conditions most people are likely to encounter, the difference in width between 225 and 255 is pretty inconsequential. The 255 is only 13% wider than the 225 (or a 225 is 11.7% narrower than a 255), which isn't that large a difference. Now, if we were going from a 255 down to a 195, different story.
This debate has raged in the off-road community for years. Is it better to go with "pizza cutters" or wider tires for various off-road conditions, especially snow and mud? Most have gone with wider tires, even in snow. Of course, they air way down (around 10 PSI) and try to float on top of the snow as much as possible. Not something we are going to do in the BMW. And frankly, if the snow is deep enough that the tire width makes that much of a difference, then the 3 series is totally the wrong car for the conditions. An SUV or 4x4 truck should be used in those instances.
Scott
08-30-2008, 10:37 PM | #18 | |
313
Rep 2,576
08-31-2008, 12:24 AM | #19 | |
111
Rep 1,764
I’m not assuming the problem is static. I’m looking at this from dynamic point of view. This is not a sliding friction problem. The problem turns into a time step free body diagram. We can assume the time frame would be 1^-6 seconds. Computationally, we can solve this problem at this time step with variable transient conditions so it is dynamic. We should be clear on this. The cross wind effect traction as it an external force but doesn’t really have much to do with narrow tires have better traction in snow. We are getting off topic. I am sure you tiring to point out certain vehicle dynamics that would be unfavourable with a wide tire in deep snow. In that case I wouldn’t disagree but not in regards with traction. Orb |
08-31-2008, 12:47 PM | #20 |
313
Rep 2,576
We are probably beating a dead horse here. I agree with you in regards to tire width and traction. The main point I am saying is that in deep snow where the snow depth exerts pressure against the front of the tire, a wider tire will not be able to pass through as easily as a narrow tire. While those forces may seem minor they are actually greater than one would expect. I can drive through 18 inches of light powder no problem. If that same snow were heavy wet snow, the car would not move. Clearly that impact is overpowering the traction capability of the tires. In this case the increased traction of the contact patch is not the issue. In this case decreasing the area of resistance would make the bigger difference in allowing the car to move.
At any rate, I go with "the wider the better for snows" as most of the time my winter driving is on packed snow. There are occasions where I have to drive in the fresh snow but they are not as often as the other conditions. Then I will usually take our Acura MDX. |
08-31-2008, 04:14 PM | #21 | |
111
Rep 1,764
• Containment displacement drag: The frontal area of the tire in relation to snow depth, density, area…ect which is treated as a drag force. There is no influence on the normal force. • Compaction rolling resistance: The vertical force is treated as rolling resistance. The horizontal component is treated as a drag force and again snow depth, density, area…ect applies. • Rolling resistance: normal force reaction in relation to deformed wheel radius. Does affect the normal force. I’m sure if you stepped through a free body diagram you draw a different conclusion, but honestly, it is not a straight forward problem. I do have the eqauations. Will agree not to agree……so enough for now. Orb Last edited by Orb; 08-31-2008 at 09:16 PM.. |
08-31-2008, 04:34 PM | #22 |
313
Rep 2,576
Good enough. I am speaking from my experience in driving in both deep snow of different types and packed snow. Where I live we get anywhere from 300-450 inches of snow every season with higher amounts above 7000 feet. The setup I use is working perfectly for my needs.
