BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BimmerCode for Flash to Pass
      11-22-2019, 08:24 PM   #1
wcs2229
wcs2229's Avatar
171
Drives: 2018 BMW X1 F48 xDrive28i
Has anyone used BimmerCode to change one-touch flash to pass from 3 flashes to 5 flashes?
I looked through the ECUs for the setting, but cannot find it. Thanks.
      11-22-2019, 09:40 PM   #2
maaii11
21
Drives: Mini F54
Hi sir
Enter in BDC_body this ECU and find out”5_FACH_TIPPBLINKEN” and then Chang to aktive
      11-23-2019, 06:34 AM   #3
Takabo
Takabo's Avatar
Japan
49
Drives: G21 320d xDrive Touring MSport
ECUs → Headunit (HU_NBT_EVO) → Expert Mode →
5_FACH_TIPPBLINKEN → aktiv(Default:nicht_aktiv)
BMW 320d xDrive Touring M Sport(G21)
Production Plant: Munich, Production Date: 2021-02-25
wcs2229170.50
      11-23-2019, 08:25 AM   #4
maaii11
21
Drives: Mini F54
Ha ha sorry I am wrong. Hu_nbt_evo is right.
Thanks for takabo-san to correct me.
Appreciate 2
Takabo49.00
wcs2229170.50
      11-23-2019, 08:26 PM   #5
wcs2229
wcs2229's Avatar
171
I do not find the setting under Headunit Expert Mode:
Last 2 items at the bottom are cut off, but not 5_FACH_TIPPBLINKEN
      11-24-2019, 06:08 AM   #6
kavatski
147
Drives: 2023 X3 30iX
You’re still one level too high - each of those headings contains a number of individual parameters. My recollection is that the one you want is under 3000 HMI, but if not, does the Android version offer a search function like the iOS version? I’ve used that several times to search for a specific entry when I wasn’t sure what section of a particular ECU it was in.
Appreciate 2
Takabo49.00
wcs2229170.50
      11-24-2019, 10:38 AM   #7
Takabo
Takabo's Avatar
Japan
49
There is also information at the following URL.
https://f48.bimmerpost.com/forums/sh...84&page=25#548
wcs2229170.50
      11-24-2019, 05:39 PM   #8
wcs2229
wcs2229's Avatar
171
I have some good news and some bad news ...
The good:
I found 5_FACH_TIPPBLINKEN under 3000 HMI in Headunit Expert Mode. I changed it to "aktiv", HU rebooted, then I exited BimmerCode, restarted car and went back into BimmerCode to confirm the setting. Thanks to maaii11, Takabo and kavatski.
The bad:
It still only blinks 3 times!
      11-24-2019, 06:52 PM   #9
Takabo
Takabo's Avatar
Japan
49
The good:
The bad:
Attachment 2186324
You need to change from 3 times to 5 times in iDrive settings.
https://f48.bimmerpost.com/forums/sh...st24551219#592
wcs2229170.50
      11-25-2019, 09:26 AM   #10
wcs2229
wcs2229's Avatar
171
Thanks, Takabo. It's working now!
Interestingly, I had sent a support request to BimmerCode about the procedure and their reply was:
"this is not possible any longer because of restrictions by BMW."
Takabo49.00
      11-25-2019, 06:17 PM   #11
kavatski
147
I like 3 blinks so I hadn't done this change but figured I'd try it on our 2019 just to check. No problem - now I have 5 blinks as an option. I'd say Bimmercode's info is out of date.
      12-03-2019, 02:09 PM   #12
pandauk
28
Drives: BMW X1
Glad you got it working. It was a right pain in the ass, it seems so simple but I was scratching my head for ages
      10-17-2021, 08:54 AM   #13
Helmetbox
22
Drives: X1
Anyone know if this method can use customise value? And if the idrive will reflect the custom value? Say if I set 4 blink, does the idrive shows 4 blink?
      10-17-2021, 08:16 PM   #14
wcs2229
wcs2229's Avatar
171
After coding with BimmerCode, you still have to go into iDrive to set the number of blinks. The coding only enables more blinks you can select.
      10-17-2021, 09:28 PM   #15
Helmetbox
22
Drives: X1
Hi there, thanks for your reply. I managed to get the 5 blink working and showing on my idrive system. However, I would like to increase the 5 blink to say 6 blink.
Wondering if that is possible.
I found this on another site
HU_NBT, Section 3000 HMI, Value 5_FACH_TIPPBLINKEN aktiv
and
BDC Body PIA_Default_TippBlinken 5 mal
However when I got into PIA_Default_TippBlinken the value don't seem to be in mal.
      10-18-2021, 08:25 PM   #16
wcs2229
wcs2229's Avatar
171
and
As far as I am aware, 5 is the maximum number blinks. Longer than that is for a real street turn.
      10-18-2021, 10:49 PM   #17
Helmetbox
22
Drives: X1
I see. Thanks. I recall previously we are able to set custom value.
xbimmers
