11-19-2019, 01:45 PM | #1 |
14
Rep 52
Stuck rear brakes - dsc/abs?
I am having a situation.. my car has been down for about a month now and i am not sure what the problem. Usually, i'm pretty good at using the search engine but i think i'm SOL with this situation. i have a 2014 335i with M Sport (blue) brakes
I've been reading a few situations likely to mine but they don't post their resolution. My rear brakes are fully compressed. it is just my rear brakes only, my fronts are perfectly fine and free spinning. On Sunday when i was working on the car, i was able to depress the brakes only when i open the bleeder but when i use the tool for depress the brakes, it bent the tool because it's stuck I have bled the brakes and that didn't help. Will bleeding the brakes with the program really help because it will activate DSC pump? I was advised to get new rear calipers but because the problem is happening to both calipers i don't think it will fix the problem. I just don't want to fork over so much money when this could be a cheaper fix if possible. i don't think the calipers are seized because when the bleeder is open, i'm able to depress the pistons. It honestly feels like there's something not allowing the brakes to depress like as if there's no return i'm not all that of a mechanic but if there's good DIY's out there, then i'll usually give it a shot. if there's a way to get this fixed without going to the dealer.. i would really much appreciate it. I don't usually run to the forum for help but i think i've asked everyone i could. i'm just being really stubborn and not wanting to spend money on calipers hopefully you guys can help me find a solution to this.. thank you everyone in advance |
11-19-2019, 01:50 PM | #2 |
Car Hypochondriac
335
Rep 901
Drives: 2014 335i M-Sport Estoril Blue
Try bleeding and doing the abs bleeding procedure as well. Can be done through ISTA.
11-19-2019, 01:51 PM | #3 |
Car Hypochondriac
335
Rep 901
If that doesn't work, get them rebuilt or buy a new set.
11-19-2019, 02:59 PM | #4 |
14
Rep 52
11-19-2019, 03:46 PM | #5 |
8245
Rep 16,088
Normally you can depress the pistons without opening the bleeder, as the fluid just makes its way back towards the master cylinder. Since both have the same symptom it's not the calipers. You need to work backwards along the brake lines until you find where the brake fluid is being prevented from flowing back.
11-20-2019, 10:47 AM | #6 | |
14
Rep 52
11-20-2019, 11:28 AM | #7 |
8245
Rep 16,088
You can find everything at https://www.newtis.info/
01-24-2024, 08:37 PM | #8 |
S.Barnes
Rep 1
Did you find a solution?
This is happening to my car as well. Did you find a solution? I have my car at the mechanic's shop and they just replaced the rear calipers, pads, rotors and said they've never seen the calipers lock like this and they suspect it's the DSC unit or components. My car hasn't thrown any codes but I took my car in because my calipers would lock sporatically while driving.
