11-13-2019, 10:30 AM | #1 |
157
Rep 928
Optimum Spring Rates
What is everyone running with their coilovers? I'm ordering a set on Black Friday and was gonna go with the default setting since fortune auto guys personally drive bmw's and I believe have the rates pretty well thought out and engineered. They are 9k front and 12k rear. I have heard from a few guys going a little softer up front and stiffer out back might be better? Ohlins has softer front and stiffer rear springs than the default. Was thinking maybe 8k front and 14k rear? Anyone have any experience with different rates? Thanks
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
11-13-2019, 11:23 AM | #2 |
480
Rep 681
It depends what your goals are. Stock is probably fine but the ride will be more choppy but many perceive that as sporty. Bilstein for example uses a rates that are pretty close together and it feels sporty but the performance is actually pretty rough and choppy. Unless you're on smooth roads or traveling at high speeds, it's quite rough.
Another consideration to take into account is the damping range that fortunes dampers are set up for. |
11-13-2019, 11:28 AM | #3 |
6420
Rep 8,500
My Ohlins R&T are running 9/16 but you know that from my previous replies
Definitely pretty firm around town but the car loosens up as the speed increases.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
11-13-2019, 11:53 AM | #4 |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
Spring rates are used to determine ride frequency (which is calculated from the spring rate and weight). So arbitrary spring rates without understanding the load is missing the main point. If someone/company says to use "x" spring rate without considering the weight (or if they recommend the same spring over various weights like for 4cyl and 6cyl models), then they haven't thought things through or done much engineering.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
thakid22287.00 |
11-13-2019, 12:39 PM | #5 | |
4528
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
11-13-2019, 12:51 PM | #6 | |
4017
Rep 3,540
Front rates are too high IMO, rears are too low, damping is typically overdamped (though I guess with B16 you can adjust that to an extent), and gas pressures are too high (making the dampers more harsh). You can probably correct the spring rates on the B16, but by that time, how much money have you spent? It'd probably make financial sense then to go with a bespoke or semi-custom setup. How much is he thinking of raising and lowering? That affects camber and toe too, so is he planning on getting alignments twice a year?
11-14-2019, 07:22 PM | #7 | |
157
Rep 928
11-14-2019, 07:23 PM | #8 |
157
Rep 928
If you had to do it again would you choose the same rates?
11-14-2019, 07:24 PM | #9 | ||
157
Rep 928
11-14-2019, 07:26 PM | #10 |
157
Rep 928
I'm leaning toward 8k front and 14k rear unless I hear some valid reasons otherwise..
11-15-2019, 08:23 AM | #11 |
6420
Rep 8,500
Yes, probably (say 80% likelihood) but I'd keep the following in mind :
I'd try and keep the effective spring rates equal F/R. The rear springs are inboard (they are not attached directly to the wheel hub, unlike the fronts) and are (say) half way between the hub and the chassis. This means that the rear spring rate is effectively halved. F/R spring rates may need to be chosen according to the actual wright distribution of the car, the weight of the engine, and the desired handling characteristics. My car has a 48/52% weight distribution and the 30d power unit is quite heavy - I found the Ohlins R&T standard front spring rate (7X) resulted in a ride which was too soft, so I increased the springs to 9X. The F/R spring rates are now much more in line with my preferences. If you're increasing the spring rates you may need to be careful with your selection for anti-roll (sway) bars. Stuff springs + stiff ARBs can compromise grip through bumpy corners. I have H&R bars F (28mm) & R (20), which were installed prior to having the R&T, and I may need to downgrade the torsional resistance by fitting slightly thinner bars. If the metallurgy was the same I'd be aiming for 25/17.
11-15-2019, 02:29 PM | #12 |
157
Rep 928
I have no plans for aftermarket swaybars. Do you think 8k ft and 14k rear would be good?
11-16-2019, 02:41 PM | #13 |
6420
Rep 8,500
Considered purely in isolation, they could be a nice choice : a step up from OEM, but not so stiff to be jarring.
I think it's unlikely that the dampers would need to be re-valved. Ohlins were happy for me to supply front springs with my chosen rate, with no damper adjustment and no loss of warranty.
11-16-2019, 03:47 PM | #14 |
4017
Rep 3,540
What level of research are you willing to do to figure out what "optimum" means with respect to your goals? It really looks to me like the numbers you're picking are kind of arbitrary.
11-19-2019, 10:05 PM | #15 | |
157
Rep 928
11-19-2019, 10:10 PM | #16 | |
157
Rep 928
11-20-2019, 06:52 AM | #17 | |
6420
Rep 8,500
