TPMS, who has installed themselves
08-28-2008, 11:37 AM | #5 |
140
Rep 1,707
it's almost too easy. To a point why you wonder the dealerships charge you an hour labor just to take them out. All you need is a 11mm socket and torrex bit to fit the sensors correctly with the barrel of your wheels and you're good to go. Don't make is SUPER tight, cuz that could ruin the rubber on the tire pressure sensors. Just moderately tight and you'll be fine!!! Let me know if you have any other questions!!!
08-28-2008, 11:46 AM | #6 |
22
Rep 965
Thanks for the info Bobby. If I remember correctly, the stems come with a rubber grommet, washer, and nut. I think the grommet goes through the stem hole on the rim and the washer sits over the grommet on the outside of the wheel and the nut then goes on. Is that the correct orientation or am I wrong? How tight do you torque the nut? Also, how tight do you torque the torx screw for the sensor. My general philosophy is tighten until it strips and then back off a quarter turn (jk)
