Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions BMW G20 Alpina Display
      11-09-2019, 09:08 AM   #1
Master0wn3r
Drives: F31 320i, F30 328i, G21 330i
After updating my e-sys I tried to code the alpina display on my new 330i.
This works both for G20 and G21
Had to code 2 values (one enabled the alpina option, and the other lets you choose between default, M or Alpina). If people are interested I will go back and check the parameters, and list them below but forgot to write them down :-(.
anyway the photos:
default (for reference)
Comfort mode:
Sport mode:
Did not take a picture of eco pro mode... who the hell uses eco pro?!
Appreciate 3
wtwo317969.50
EXE462100.00
      11-09-2019, 10:51 AM   #2
dgg_bimmer
Drives: BMW M340i xDrive
Wow. Great news looks better
      11-09-2019, 11:03 AM   #3
wtwo3
wtwo3's Avatar
17970
Drives: 23 X7 40i; 23 M3; 24 cooper s
That's pretty cool
2023 BMW X7 xDrive40i
2023 BMW M3 6MT
2024 Mini Cooper S Convertible
'20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima
      11-09-2019, 11:09 AM   #4
Master0wn3r
Indeed, looks better!
Will add the possible M3 gauges in a few days.
      11-09-2019, 01:55 PM   #5
mrgicm
mrgicm's Avatar
441
Drives: BMW M
Does your tacho read the correct speed? I coded mine and now the tacho is reading different speed than the digital speed? The difference is around 30kmh. Does anyone know how to fix that?
      11-09-2019, 02:04 PM   #6
Master0wn3r
Yes mine is working fine, confirmed it with my gps. Earlier models are on an previous system software (istep 539 I believe) My Touring is on 560 as they were released later. Updating solves this problem!
      11-11-2019, 09:29 AM   #7
Basti@G20 320D
Basti@G20 320D's Avatar
Sweden
25
Drives: E30, E36, E46, F30, G20
I have the same problem, its not showing the right speed.
Coded with Bimmercode Testsfligth.
      11-11-2019, 09:41 AM   #8
Master0wn3r
When did you get your car, mine is made at September 13th and has the software revision where it is fixed.
      11-11-2019, 03:52 PM   #9
mrgicm
mrgicm's Avatar
441
Drives: BMW M
It is just a matter of software, I will update my KOMBI this week with later software and hope it will fix the issue
      11-13-2019, 02:15 AM   #10
PunkSinatra
78
Drives: Alpina D5S
Hello, I'm new to the coding world, never done before.
I will get my car in a week, it's a m340i. Currently drive a f80.
Can you please tell me what I need to code the alpina dials?
Which obd reader are you using? I need to buy one, and don't want to buy the wrong one.
I was hopping bimmercode would work as it is pretty straightforward.
Thanks in advance for your reply.
      11-13-2019, 02:41 AM   #11
Master0wn3r
I will check what the values are, I have never used bimmercode but I read that it is pretty easy to use and straight forward. If you are unexperienced I advise you to look up how Bimmercode works.
I have been using E-sys with an ENET cable for years, is not hard to use at all but is a bit different than bimmercode.
      11-13-2019, 09:51 PM   #12
siegester
siegester's Avatar
345
Drives: '20 M340i
2020 BMW M340i  [0.00]
Nice. Do you use launcher pro for the coding on this? I haven't coded since my e82 days, but would love to play around with things like this
      11-13-2019, 11:05 PM   #13
tommytexter
tommytexter's Avatar
182
Drives: 2020 M340ix
Will u be kind enough to let me know which module and which value to change? I am familiar with esys and launcher pro. I coded my f32 and a lot of other people's bmw..only need to the value.
      11-14-2019, 04:00 AM   #14
Master0wn3r
You need launcher pro 3+ and de data files, I coded DKOMBI2 module. In there there are 2 lines to be coded:
ALPINA_ENABLE = AKTIF
and then you have to do a find action in the opened ncd with the word alpina, once you hit a parameter with Alpina in the description you have to change that one. Its in a parameter with kombi layout or something, you can also change it to M mode. 3 options there (bmw (default), alpina and M) so you should be able to find it quickly.. once I exactly know the parameter I will post it. But I am sure you should be able to find it with this info.. if unsure send me a pic and I wil verify :-).
When you google you will only find you have to code ALPINA_ENABLE = AKTIF but this is not true, only coding this changes nothing.. it only enables the layout to be chosen in the next parameter.
      11-14-2019, 07:19 AM   #15
tommytexter
182
Drives: 2020 M340ix
Thank you! I will try once I get my m340i at the end of this month! Also, which version of PZdata are u using?
      11-14-2019, 07:57 AM   #16
Jbrock22
Jbrock22's Avatar
222
Drives: 2pw
BMW   [0.00]
Bimmer code is idiot proof. Just sayin.
      11-14-2019, 10:20 AM   #17
Master0wn3r
It may be, I cant judge I have never used Bimmercode, but the values and such edit almost the same way as on e-sys so it doesnt really matter.
      11-14-2019, 10:28 AM   #18
Master0wn3r
I am using 4.18.33, which is second to latest version.. I have a link for that if you need.
      11-14-2019, 10:56 AM   #19
tommytexter
182
Drives: 2020 M340ix
Thanks, but I can find it.
      11-19-2019, 04:12 PM   #20
mrgicm
mrgicm's Avatar
441
Drives: BMW M
So I tried the M version tacho and the speed is correct on this one, so its just the alpina version that shows the wrong speed. Very strange the i Step on the car is 07-19.
      11-20-2019, 05:03 AM   #21
Master0wn3r
Wierd, mine has like 2kmh difference with the gps. Mine has the July update aswel, maybe the cluster needs an specific update
      12-03-2019, 06:35 PM   #22
sweetcar
Drives: bmw & f30
Alpina coding
I'm sorry, but can you know the Alpina coding coordinates ??
g20
