BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Stalling issue on startup - 2019 M5 comp
      11-08-2019, 05:04 PM   #1
Steeve19M5CP
194
Drives: 2019 MBB Blue M5 Competition
Recently I am getting a new issue when starting up the car.....I press the startup button and the car starts but immediately stalls and engine cuts off.....I press the start button again and then all is fine........anyone have this or any ideas?
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package
2013 Lamborghini Aventador-Pearl Green-Modified
2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified
2018 Range Rover Velar S-White
      11-08-2019, 08:05 PM   #2
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Same exact problem.
Happened to me tonight ... drove 10 miles .... watched my son's basketball game ... about an hour and a half later I started the car and it died ... tried again and started right away.
This has been happening for about 6 months and always as described above.
I've discussed it briefly with my SA but have not taken the car in.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      11-08-2019, 08:37 PM   #3
Steeve19M5CP
194
Time to bring it in for service
      11-08-2019, 10:18 PM   #4
MCOMP
MCOMP's Avatar
199
Drives: 19' M5 Comp.
Happens occasionally, not worth a trip to dealer,
2019 MBB/Aragon M5C
M Performance: Exhaust Tips/Pro Spoiler/Rear Diffuser. H&R 11/11 Spacers ACG Carbon Kevlar Pads XPEL Front PPF Ceramic Pro Silver 20% Tints Instagram #m5comp
      11-09-2019, 09:01 AM   #5
josec70
josec70's Avatar
This was my exact thinking ....
      11-09-2019, 03:52 PM   #6
A Need For Speed
A Need For Speed's Avatar
378
Drives: 2019 M5 Comp Nardo/Aragon
And mine. Seems like very occasionally the starter tries to turn over that big boy and just says fuggedaboutit.
      11-09-2019, 04:19 PM   #7
JRod1980
392
Drives: 2019 BMW M5 Competition
I have the same issue. I've talked to the M tech at my local dealer who said that he's seen it happening on 3 other F90s. Apparently something is wrong with the fuel pump not pumping sufficient gas at start up.
He had to change one on another F90 as it happened way too often. Apparently the issue still remains and the customer is trying to lemon law the vehicle. Fuel pump is not an easy change either as they have to take out the back seat to get to it, sounds like more than one day of work.
I don't mean to scare anyone and I'm no expert, but it's worth sharing. I have no performance issue with my vehicle when it happens and seems like it's only at start up. It doesn't happen often enough for me to bring it in and go through the hassle. Perhaps have them check it next time you're in for service. However, apparently the issue is very common so it wouldn't surprise me if they do a recall.
      11-09-2019, 06:04 PM   #8
Steeve19M5CP
194
Problem is that yes it was occasional say one time per month but now its twice per week.....so will call dealer to see if they have a known fix
      11-09-2019, 06:56 PM   #9
ambletx
ambletx's Avatar
516
Drives: 2021 M5 Comp
I was wondering about this myself. I'd say it happens about 1 out of every 15 starts for me. Like others have said, its not worth another trip to the dealership though.
      11-09-2019, 07:36 PM   #10
Steeve19M5CP
194
Still not acceptable and some may say embarrassing on a 125k car
Appreciate 6
      11-09-2019, 08:36 PM   #11
A Need For Speed
378
Not sure it’s anything more than a intermittent issue. We shall see.
      11-10-2019, 11:12 AM   #12
swisstype
Twisted Fister
Drives: 2018 F90 M5; 2024 Roma
I had this issue. They replaced 2 High pressure fuel pumps and that still didn't fix it, so they replaced a low pressure fuel pump. I was told to run 2-3 tanks of gas with NO ethanol and then back to normal. hasn't happened to me since.
      11-10-2019, 11:32 AM   #13
A Need For Speed
378
How long was it in dealership for the low pressure pump replacement? Do you know if the back seats had to be removed?
      11-11-2019, 12:24 PM   #14
Steeve19M5CP
194
are you done with the testing period? confident it is the proper fix?
      11-11-2019, 03:36 PM   #15
swisstype
Twisted Fister
Maybe 2 days
      11-11-2019, 03:37 PM   #16
swisstype
Twisted Fister
I do... It has not happened since.
      11-17-2019, 02:26 PM   #17
wassy
30
Drives: 2018 Bmw M5
Same here. Also seeing multiple Cranks before starting as well as it starting, then sounding like it’s about to shut off and catches itself and stays on. Service tomorrow and will see
      11-17-2019, 03:06 PM   #18
FloridaM5
FloridaM5's Avatar
Drives: 2021 M3 Comp RWD
  [5.83]
Originally Posted by wassy View Post
Same here. Also seeing multiple Cranks before starting as well as it starting, then sounding like it's about to shut off and catches itself and stays on. Service tomorrow and will see
Same here, but never more than 2 cranks to start.
      11-17-2019, 03:41 PM   #19
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
Happened the other day. Unless it becomes a regular thing I’m not worried about it
      11-17-2019, 04:43 PM   #20
calpharo
calpharo's Avatar
37
Drives: 2018 M5
2016 BMW 740i  [0.00]
2019 BMW X5  [0.00]
2018 BMW M5  [0.00]
Happened to me three times today alone . Before today happened less than 5 times. Not sure if it was the fuel that I last used at the last fill up (Shell 91 octane, best we got here in Cali)
      11-18-2019, 08:22 AM   #21
Steeve19M5CP
194
ok so I tried the Lucas injector cleaner and so far hasnt happened in 1 week......will wait another few weeks to report back but so far looking good
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      11-18-2019, 09:16 PM   #22
josec70
josec70's Avatar
https://www.amazon.com/gp/product/B0...UTF8&psc=1
Keep us posted .....
Search this Thread:
Advanced Search
