F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > What parts to retrofit Msport blue brakes
proTUNING Freaks
      11-03-2019, 04:28 AM   #1
jedi-knight83
51
Drives: F36 430d GC, XKR, Clio 172
I might have an opportunity to strip a set of blue Msport brakes from a 320d F30.
I have a 330d F31.
Other than the obvious parts, callipers, carriers, disks, stone guards etc.... what else will I need?
Was the brake servo and master cylinder the same between the standard brakes and Msport brakes?
Will I need to code the car?
Thanks in advance.
Midnight Black Jaguar XKR Convertible | Saphire Black BMW F36 430d Gran Coupe | Iceberg Silver 2002 Renault Clio 172 Track Car
      11-03-2019, 10:32 AM   #2
draggy
sucka for a longroof
29
Drives: F31
I have a 330d F31.
Thanks in advance.
You may want to think about different pads that dust less or going with stainless steel lines but other than that it's just swap, bleed, then go.
      11-03-2019, 03:47 PM   #3
5mall5nail5
Not stock
5mall5nail5's Avatar
Drives: E34 525i Turbo
Coding, most importantly....
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM
1992 525i
1987 325e
erron8.50
      11-03-2019, 05:34 PM   #4
jedi-knight83
51
can you elaborate on this please?
What needs coding?
      11-04-2019, 10:15 AM   #5
5mall5nail5
Not stock
What needs coding?
What brake setup do you currently have on the car? Are they the single piston units all around?
1992 525i
1987 325e
      11-04-2019, 12:16 PM   #6
jedi-knight83
51
Yes. In the UK there are 2 options.
Standard brakes - single piston, unpainted. 340mm front
Msport brakes - 4 bot, painted blue, 370mm front for 330d or 340mm front for lower models
      11-04-2019, 01:24 PM   #7
5mall5nail5
Not stock
Right - so given that you have standard brakes you will need to code for S2NHA or "SPBR" in E-SYS. If you just install 4 piston front and 2 piston rear calipers on your car without having SPBR coded, the brake pedal nearly goes to the floor.
1992 525i
1987 325e
johnung4528.00
      11-04-2019, 01:59 PM   #8
johnung
Drives: 2015 BMW 335i x-Drive Auto
Are you aware that the M Sport brakes with the 370mm front rotors and the 345mm rear rotors will only fit under 18 inch and larger road wheels? You cannot use 17 inch wheels with these brakes.
A friend of mine in Europe went through a similar brake upgrade. There can be a compatibility issue with the rear parking brakes. The rear parking brakes are a drum brake design. The "drum" is actually the inside of the rotor hat of the rear brake rotor.
The F30 models actually use two parking brake sizes. Most use 185mm diameter parking brakes which is what the M Sport 345mm x 24mm rear rotors have. But some of the lower F30 models use smaller 160mm diameter parking brakes. It's a very subtle difference to the eye because the rotor hats themselves are just 25mm less in diameter.
If you happen to have the smaller 160mm parking brake there is a solution. Don't even think about swapping rear hubs and parking brake components. It's way too expensive and labor intensive. But there are available aftermarket rotors in 345mm x 24mm with the smaller rotor hats to contain a 160mm parking brake. If you run into that problem let me know and I can try to get you a source and part number from my friend.
Hope this helps!
      11-04-2019, 02:11 PM   #9
jedi-knight83
51
Thanks for the info. Can you code this with the bimmercode app?
      11-04-2019, 02:13 PM   #10
jedi-knight83
51
Hope this helps!
Starting to sound like a pain of an upgrade. I've already decided to take a miss on the 320d brakes as they will only be 340mm.
But now it sounds like I will have the wrong parking brake set up as well as mine just has the small brakes as standard. How would I check which parking brake set up I have?
Oh but at least I already have the 19" wheels. I think all Msport models in the UK came with 18" minimum size
      11-04-2019, 02:30 PM   #11
5mall5nail5
Not stock
If you take a picture of your rear rotor/shield area we could tell you. It's not an issue with the parking brake, its an issue with which rotor you need and what shields you need. My 2015 328 (RWD) had the "large hub" rotors, despite everything saying 328's have small hub. BMW started using all large-hub stuff like 4/15 or something. I think I documented it some where.
That, and some cars have a small rear rotor shield that won't fit over the 345mm rear rotors in the M perf/M sport kit. Its not as bad as it sounds. Easy to sort out once you know the caveats.
1992 525i
1987 325e
      11-04-2019, 03:15 PM   #12
johnung
Hope this helps!
Please don't be discouraged. This is a tremendously worthwhile upgrade to end up with 4-piston Brembo fronts and 2-piston Brembo rears, either in 370/345 or 340/345 flavors. The full Brembos are so much better than what you have.
Odds are that you have the larger parking brake. I just wanted you to know what the issues were if you ran into it. See the attached photo. With your VIN you can quickly look up which of the two brake shoe sizes your car has.
Definitely upgrade to stainless steel brake lines at the same time. StopTech set is only $106. Much better brake pedal feel.
      11-04-2019, 03:33 PM   #13
jedi-knight83
51
Ok it says mine is 185mm. So that's one less thing to worry about at least.
      11-04-2019, 06:46 PM   #14
5mall5nail5
Not stock
yep and even if it was the smaller size there is a BMW rear dimple slotted rotor for that. I was sent it by mistake. either way though it's not horrible. no, it can't be coded via Bimmercode unfortunately.
1992 525i
1987 325e
      11-04-2019, 07:00 PM   #15
draggy
29
Drives: F31
I was under the impression only the 370mm upgrade needed coding - there's even a coding option for the 340mm upgrade from standard brakes?
      11-05-2019, 03:40 AM   #16
jedi-knight83
51
Balls. Even I expert mode on Bimmercode?
Whats the other program I need then please?
      11-06-2019, 09:25 AM   #17
johnung
The coding is the same for the 340 and 370 calipers. They are exactly the same 4-piston Brembo calipers. The piston diameters are identical in both of them. So for instance if your car came with grey front Brembos in 340, you can upgrade to 370 without having to code.
The only difference is in the length of the casting since the bolt holes in the 370 calipers are 15mm further out from center to fit the rotors than are 15mm greater radius (30mm greater diameter. You would have to have a great eye to spot the difference.
But if you flip the front caliper over the 340 has a raised "340" on it. The 370 front caliper has a raised "370/380" on it. (The same caliper mounts on an M car and fits a 380mm rotor, and NO you can't fit a 380mm rotor on an F30!) See attached photos.
      10-07-2020, 07:32 PM   #18
Chris_ks
23
Drives: F20 lci
Hope this helps!
Hi, i am planning to fit blue m sport brakes on my F20.. I saw on real oem and my “Supporting ring brake shoe” is D=160MM.
Then i checked about rear discs, Ate and Zimmerman(150.2921.20) rear 345mm discs described as internal drum’s diameter —> 161mm.
Is this the “problem” which you described? And if they say internal 161mm, does it mean that these rear discs are suitable for my 160mm drums ?
Thanks for your help..
      10-07-2020, 09:15 PM   #19
johnung
Hope this helps!
The Zimmermann part number that you mentioned, according to my notes, is a rear 345mm x 24mm rotor with a internal handbrake diameter of 160mm. If you found something that happens to list it as being 161mm, I'm sure that it's the same part. With the F3x there are only two sized handbrakes: 160mm and 185mm.
You say that you have an F20 which is a 1-Series. It sounds like from your statements and questions that the F30 and F20 may use some of the same parts. You said that you are going to upgrade to blue M Sport Brakes.
BMW throws around the "M Sport" marketing label so it means different things on different F3x models. I don't really know what "M Sport" means on whatever F20 model that you have.
Sorry, I have experience with F3x brakes but I don't know much about F20 brakes.
      10-08-2020, 12:21 PM   #20
Chris_ks
23
Drives: F20 lci
Hi, it’s exactly same brakes on F20 and F30 that’s why i asked you.
The blue brakes “M sport” will be front with 340mm discs and rear with 345mm discs.
Blue calipers are as mentioned four piston front ones and 2 pistons rear ones.
So My only question is about the “problem” you said for rear ones where i can confirm that I have 160mm drums as real oem says..
So the solution is to fit the above discs as i explained or is anything else that i need ?
      10-08-2020, 01:26 PM   #21
Boostedphil698
Boostedphil698's Avatar
Drives: 2015 BMW 435i Xdrive MSport
2015 BMW 435XI  [0.00]
2009 Honda Civic  [0.00]
Jeasus christ, just buy the M Performance BBK and you'll have all the hardware except rear rotors. Piecing together a kit is tedious. Coding needs to be done, it changes how fluid travels to the two piston caliper in the rears as opposed to the singles you have now.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily)
      10-08-2020, 02:47 PM   #22
Chris_ks
23
Drives: F20 lci
I didn’t ask about coding, I know that it needs coding.
M performance needs 18” wheels at least, I want to use 17” wheels and there is no need for me to spend the amount M performance BBK costs!!
If you have any help about my question it would be helpful, otherwise your comment is completely off topic!
Logicoeur992.50
f30post
