BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Noisy Braking from High Speed
      11-02-2019, 10:03 PM   #1
wcs2229
wcs2229's Avatar
171
Drives: 2018 BMW X1 F48 xDrive28i
When I brake firmly (but not panic) on the highway at high speed (~60-75mph or ~100-120km/hr), it feels rough and is noisy.
At lower speeds (below ~60mph or ~100km/hr) braking is smooth and quiet.
Has anyone experienced this? My car is 2018 X1 F48 with ~12,000 miles/~19,000km.
      11-03-2019, 04:21 AM   #2
Beagler
United Kingdom
75
Drives: Sept 2019 Facelift X1 MSPORT
You apply more force on the pedal at higher speed so whatever is causing it is louder. The usual suspects are edge corrosion round disc(rotor), grit or foreign object contamination in pads or pad wear.
Everthing goes to Entropy in this Age.
      11-03-2019, 10:51 AM   #3
oakey46
United Kingdom
159
Drives: BMW 2 A/T 220i Lux Auto 1.5
It could also be the ABS system kicking in if you are using heavy pedal pressure, because of way the ABS unit functions.If that is the case, it's quite normal.
      11-04-2019, 02:56 PM   #4
landrumdh
14
Drives: F48
I have similar issues but my quiet breaking is < 45mph. I've already has the pads and rotors replaced once and it came back only a few thousand miles later. I suspect it's sub-quality parts or a design problem. This is probably one of my largest complaints about the car and my passengers notice it as well which is embarrassing.
      11-04-2019, 03:13 PM   #5
Beagler
United Kingdom
75
There is a fix for another brake problem ie squeal. Copper grease between the shim and the rear of the pad. To prevent grit and water build up between pad and disc(rotor), two hacksaw blades together make a horizontal cut in the pad material to form a channel for water and grit. This may also resolve this problem.
      11-06-2019, 09:01 PM   #6
wcs2229
wcs2229's Avatar
171
I went in for service and replaced all brake pads and rotors ... OUCH!
They said there was some rust on the rotors and they do not machine rotors, only replace them.
      11-07-2019, 05:33 AM   #7
kavatski
147
Drives: 2023 X3 30iX
New brakes all around at 19,000 km? Yikes. Did they give you any indication of how much life was left in the pads at that point?
      11-07-2019, 05:59 AM   #8
Beagler
United Kingdom
75
I think the X1 is heavier on brakes because mine in eco mode coasts when I let my foot off the throttle. You can watch the rev counter drop to idle as it coasts then goes up as I apply throttle. The result is I brake more often to keep within the speed limit and approach other vehicles as the engine braking is absent. Its got to attract greater brake wear.
      11-07-2019, 08:26 AM   #9
wcs2229
wcs2229's Avatar
171
The problem with my brakes was not really the pads, but the rotors. They said there was 5mm left on the pads, which is still ~40% left before triggering the brake sensors. They do not replace only the rotors without replacing the pads.
I only put on ~4,000 km/2,500 mi since buying the 1-year used car. The car may have sat for sale during the Toronto winter, hence rust buildup. I could have left them and driven anyway, but I don't like the feeling of noisy brakes.
      11-09-2019, 02:27 PM   #10
oakey46
United Kingdom
159
Mine was in for service just over a month ago at 18,000mls (c28800km) and the service report said that I still have around 5mm remaining on the pads and discs/rotors all OK too.
      11-09-2019, 09:46 PM   #11
wcs2229
wcs2229's Avatar
171
I do notice that my brakes are much smoother now ... they were grabbing before. Hopefully, I'll get more mi/km by not letting the car sit over winter.
xbimmers
