10-31-2019, 02:58 PM | #1 |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
Coding reversing camera via Bimmercode
Just installed an aftermarket reversing camera to my F30 with NBT headunit.
I now need to do the coding, but only have Bimmercode. I've been given the below instructions to code. REM_01 > PdcParkMasterVar 3203 > RVC = wert_02 REM_01 > PdcVarCoding 3200 > PDC_VORHALT_2 = aktiv HU_NBT > EXBOX 3001 > AUX1_IN_HU = wert_255 [Default] HU_NBT > EXBOX 3001 > CAMERA_SYSTEM = trsvc HU_NBT > EXBOX 3001 > MACRO_RV_C = aktiv HU_NBT > EXBOX 3001 > TRSVC = wert_81 The problem is that there is no activ option on my car REM_01 > PdcVarCoding 3200 > PDC_VORHALT_2, it just says wert_01. Does anyone know what I can do as I just have blank video coming through when I select reverse.
10-31-2019, 04:00 PM | #2 |
588
Rep 2,302
Don't know from where you've got these values, but the value
REM_01 > PdcVarCoding 3200 > PDC_VORHALT_2 = aktiv is not needed for the rear view camera. This value stays the same with or without camera. |
10-31-2019, 04:57 PM | #3 |
Regular user
224
Rep 965
Thanks. The company I bought the aftermarket kit from said that one of their customers used those values with success. I'll put mine back to the default which was wert_01.
They advised coding 3AG via E-sys, but I don't have it and if their customer was able to get it working via Bimmercode then I'm hoping that I can too.
11-01-2019, 01:53 PM | #4 |
Regular user
224
Rep 965
Sorted it. Just
Mods feel free to delete.
11-02-2019, 01:32 AM | #5 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
11-02-2019, 03:35 AM | #6 |
Regular user
224
Rep 965
Yes. It's on a retrofit thread, but basically I uncoded what I had done in Bimmercode and left the car to shut down. Went back a few hours later and did the following coding in Bimmercode:-
REM_01 > PdcParkMasterVar 3203 > RVC = wert_02 HU_NBT > EXBOX 3001 > AUX1_IN_HU = wert_255 [Default] HU_NBT > EXBOX 3001 > CAMERA_SYSTEM = trsvc HU_NBT > EXBOX 3001 > MACRO_RV_C = aktiv HU_NBT > EXBOX 3001 > TRSVC = wert_81
Alimaala6.00 |
06-28-2020, 02:07 PM | #9 | |
Rep 12
Thanks |
06-29-2020, 09:31 AM | #11 | |
Rep 12
06-01-2022, 08:41 AM | #12 | |
Rep 2
Reversing camera
Can you give me the name and model of your reversing camera please ? PS: Or maybe another one that can be coded with Bimmercode because I only have Bimmercode. |
06-01-2022, 10:41 AM | #14 |
Rep 2
06-01-2022, 11:58 AM | #15 | |
E36fiend
285
Rep 637
This is why it's always "better" to use a tool like e-sys to add the 3AG option code which will automatically apply the appropriate FDL coding. Look/post in the local forums to see if anyone in your area has e-sys and can trade you their time in exchange for a 6 pack or something. |
