10-25-2019, 07:48 PM | #1 |
118
Rep 218
Bimmercode TRSVC Module Issue
So I'm just now getting ready to code my car via Bimmercode and an OBDLink MX+. One of the things I wanted to code is to turn off the speed sensitivity on activating the side view cameras.
When I connect to the car, however, I get that the coding data on the TRSVC ECU is invalid and therefore cannot be coded. Downloaded Bimmerlink and it says there is a code 800BD1 (Coding: Control Unit not coded) error that is currently present. About a year ago, one of the side view cameras was replaced and the tech wrote "Removed and replaced TRSVC Control Module. After replacement performed program and coding of new control module." The cameras work fine currently but I'm not able to code as desired. Any ideas on how to fix this? How would I go about explaining the problem to the SA at BMW dealership? Would they fix it if the underlying electronics are functioning appropriately? Thanks so much! |
10-25-2019, 09:23 PM | #3 | ||
118
Rep 218
It shows up as attached: |
10-25-2019, 10:02 PM | #5 | |
118
Rep 218
Alternatively, would you happen to know the oldest windows operating system esys is compatible with? |
10-25-2019, 10:37 PM | #6 | ||
184
Rep 780
alistairk117.50 |
10-26-2019, 11:58 AM | #8 | |
118
Rep 218
Thanks so much for your guys' help! [edit: realized question had been answered previously] |
10-30-2019, 05:51 PM | #9 |
118
Rep 218
So thanks for all your input! Took it to the dealer and they tried to encode the module and it wouldn't take so they had to finally encode via IRAP (supposedly linking directly with BMW in Germany).
End result is the error is cleared! |
