BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Presenting the AWE S-FLO Carbon Intake Suite for the F9X M5/M8. Available now.
      10-25-2019, 02:39 PM   #1
Josh/AWE
Josh/AWE's Avatar
Drives: AWE M4, AWE 328
Arrow Presenting the AWE S-FLO Carbon Intake Suite for the F9X M5/M8. Available now.
BIMMERPOST
     Featured on BIMMERPOST.com
High spooler. Presenting the AWE S-FLO Carbon Intake Suite for the BMW F9X M5/M8, available now:
  • Designed, engineered, and tested in-house at AWE
  • Max gains of 7 hp and 7 ft-lbs of torque at the wheels with stock software
  • 56% increase in filter surface area over stock
  • Modular design allows multiple configuration options
  • Available with or without S-FLO Carbon Covers -- change intake volume as desired
  • S-FLO Carbon Grille Inlets available separately or with S-FLO Carbon Intake
  • Easily convert between covered and uncovered within seconds
  • S-FLO Carbon Grille Inlets optimized to capture significant amount of ram air over stock
  • Smooth, direct transition from S-FLO Carbon Grille Inlets to S-FLO Intake
  • Features durable and washable high-flow AWE S-FLO Filters
  • Perfect integration with OEM inlet ducting
  • Retains stock mounting locations for OE-like fit
  • Genuine 2x2 carbon fiber construction
  • UV-stabilized resin and clear coat
  • Perfect fitment, guaranteed
  • AWE No Check Engine Light Guarantee
The Options:
S-FLO Carbon Intake:
Dual filters with a 56% increase in surface area over stock, threaded seamlessly through the factory bracing with a sophisticated touch of 2x2 carbon fiber. Thanks to this increase in surface area, the M5ís S63 takes kindly to the respiratory refinement, translating 7 hp and 7 ft-lbs of torque to the wheels on factory software with plenty of room for upgraded software that demand higher-than-stock boost levels.
The S-FLO Carbon Intake is the perfect option for those seeking more volume from their intake when under boost. Want to hear more turbo induction sound from within the cabin? Good, we hoped you would. Equip S-FLO and full spool ahead.
S-FLO Carbon Covers:
The S-FLO Carbon Covers share the same 2x2 carbon fiber construction as the S-FLO Intakes, even down to the weave direction. Featuring a raised ceiling right above the S-FLO Filters and perfect integration to the factory air ducting, the S-FLO Carbon Covers allow a significant amount of ram air to surround the intake while keeping it stealthy in the sound department.
Mounting securely to the factory mounting points, the S-FLO Carbon Covers rid the plastic in exchange for an aesthetic fit for the F9X.
S-FLO Carbon Grille Inlets:
Trumping the factory inlets in every way, the S-FLO Carbon Grille Inlets utilize empty space behind the kidney grille for capturing charged air from the front of the vehicle. Facing forward instead of up (e.g. stock) allows the S-FLO Carbon Grille Inlets to funnel the charged air directly into the ducting behind the headlight and into the intake seamlessly. Adding form to function, the S-FLO Carbon Grille Inlets introduce a unique grade of aggression to the M5ís front end.
The S-FLO Carbon Grille Inlets are the perfect compliment to the S-FLO Carbon Intake, and also work with the factory intake configuration.
Upgrade options:
The S-FLO Carbon Intake can be purchased with or without the S-FLO Covers and Carbon Grille Inlets. If you want to add either at a later date, no problem.
Whatís in the box?
Complete S-FLO Carbon Intake, S-FLO Carbon Covers and/or S-FLO Carbon Grille Inlets (if chosen), two S-FLO Filters, and all necessary hardware for installation.
Please note: we include rub strips to prevent damage from the factory bracing. Please see our installation instructions for proper application.
Data:
      10-26-2019, 02:00 PM   #2
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
      10-29-2019, 10:37 AM   #3
Real_Talk_With_Matt
Real_Talk_With_Matt's Avatar
Drives: BMW M5
Can't wait to get my hands on this
      10-29-2019, 11:25 AM   #4
windtendo
windtendo's Avatar
795
Drives: Nardo F90
2019 BMW M5  [0.00]
Wow, that's a beautiful design!
IG @windtendo_m5
      10-29-2019, 12:20 PM   #5
mike@x-ph.com
Agree
      10-29-2019, 02:39 PM   #6
Josh/AWE
Josh/AWE's Avatar
You're going to love it, M!
      10-29-2019, 02:40 PM   #7
Josh/AWE
Josh/AWE's Avatar
Originally Posted by mike@x-ph.com View Post
Agree
Thanks, gentlemen! A good looking, modular performer
      11-01-2019, 03:03 AM   #8
soopa
87
Drives: 2018 F90 M5
Looks great! I like the idea of reusing the stock airbox + CF cover.
      11-01-2019, 09:12 AM   #9
Josh/AWE
Josh/AWE's Avatar
Thank you!
Our S-FLO Carbon Covers do not work with the stock airboxes -- only with the S-FLO Carbon Intakes.
      11-01-2019, 11:37 AM   #10
bm5bullit
bm5bullit's Avatar
Drives: 2019 BMW M5
Beautiful design and the looks are great. Just curious - how many pulls did you do the rollers? Do you think that the DME had completely adapted to the CAI? Your whp reading seems awful low to me. You might want to look into that.
2019 M5 - AW, Aragon ext. lthr, Carbon roof, B&W, BBS wheels, exhaust, Executive pkg..........
2017 Audi A8L - her car
2013 M5, AW, DP's, MSR CAI, Spec R, SOLD
2018 Chev. ZR2 truck, Daily Driver
      11-01-2019, 01:33 PM   #11
Josh/AWE
Josh/AWE's Avatar
The data shown is representative of the average results between 5 runs. Standard protocol throughout years of extensive experience owning/utilizing a chassis dyno in all of our development efforts. No fluff here, just realistic, repeatable numbers.
      11-02-2019, 08:29 PM   #12
onfireX5
2678
Drives: F90M5,F85X5M
The Chart has "engine hp ". Is it engine or rwhp ?
      11-04-2019, 08:49 AM   #13
Penguino
Penguino's Avatar
478
Drives: A car.
Looks good. At least it's not $1800.
"Beware of false knowledge; it is more dangerous than ignorance."
      11-04-2019, 09:19 AM   #14
phantom7835
phantom7835's Avatar
Drives: 20 M2C, 92 Miata
Looks like a good intake from honest shop that's not gonna claim crazy numbers. All of these fancy intakes shouldn't have any significant power expectations past looking very good, and this one certainly looks very good
It's a shame BMW has so much matte black plastic in the engine bays these days
2020 M2 Competition, LBB, Exec, 6 Speed
2013 X1 x28i, Valencia, Premium, Cold Weather
2002 325i/5, Tiag - sold
1998 M3/4/5, Cosmo - scrapped
1992 Miata, Brilliant Black, STS - on the island of misfit toys
      11-04-2019, 09:48 AM   #15
bm5bullit
bm5bullit's Avatar
Drives: 2019 BMW M5
My personal experience with a couple of intakes for the F10 M showed repeatable gains during the years that I had it up until I had a complete re-map and tune. Then the numbers were up there.
      11-04-2019, 01:02 PM   #16
isanube
isanube's Avatar
11
Drives: 2018 M5 Alpine White, 1992 R32
Price?
Give me a follow on IG @shiro_f90
      11-04-2019, 02:16 PM   #17
Ghostriderf80
Got Tools?? Use them.
Ghostriderf80's Avatar
490
Drives: Just a BMW
The Options:
Dual filters with a 56% increase in surface area over stock, threaded seamlessly through the factory bracing with a sophisticated touch of 2x2 carbon fiber. Thanks to this increase in surface area, the M5’s S63 takes kindly to the respiratory refinement, translating 7 hp and 7 ft-lbs of torque to the wheels on factory software with plenty of room for upgraded software that demand higher-than-stock boost levels.
Trumping the factory inlets in every way, the S-FLO Carbon Grille Inlets utilize empty space behind the kidney grille for capturing charged air from the front of the vehicle. Facing forward instead of up (e.g. stock) allows the S-FLO Carbon Grille Inlets to funnel the charged air directly into the ducting behind the headlight and into the intake seamlessly. Adding form to function, the S-FLO Carbon Grille Inlets introduce a unique grade of aggression to the M5’s front end.
Upgrade options:
What’s in the box?
Data:
Makes power, the other ones from uk do not. They are just expensive. But they did break 200mph in the M5. So I dunno. Some competition to be had.
1980 VW Rabbit 8v- 4spd - #1 First car - Thanks Dad.
1998.5 Audi A4 - very nicely built
2010 E90 325i M-Sport - M3/330i conversion, BBK/LSD FAST!
2014 M5 AKA Tomahawk Cruise Missile
2016 M3 Comp DCT - GTS flash, ESS, Akra DP, MPCO - Nirvana achieved
      11-04-2019, 04:40 PM   #18
Josh/AWE
Josh/AWE's Avatar
"Power to the wheels."
      11-04-2019, 04:41 PM   #19
Josh/AWE
Josh/AWE's Avatar
Originally Posted by isanube View Post
Price?
Options start at $699.
      11-04-2019, 04:49 PM   #20
isanube
isanube's Avatar
11
Price?
When do you release?
      11-04-2019, 07:09 PM   #21
VeNoM__M5
44
Drives: F90 M5 Competition
Price?
Any dyno numbers of just the inlets on a stock airbox? Had the RPI scoops back in the day on my e60 M5 and those had very slight improvements with a stock box, CF removal and BMC drop-ins similar to your chart.
      11-05-2019, 09:05 AM   #22
kev...
kev...'s Avatar
123
Drives: 2018 M3
The Options:
Upgrade options:
What’s in the box?
Data:
What's better AWE S-FLO intake or eventuri?
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
