10-25-2019, 07:54 AM | #1 |
48
Rep 170
Some of Driving Assistand functions temporarily disabled
I just getting this info, stating that "radar" might be blocked, but I cannot find anything on it...
it is very wet/raining, could this be the cause? |
10-25-2019, 09:13 AM | #2 |
145
Rep 379
Happened to me a few weeks back around dawn in the pouring rain on the way to the airport. Was fine again when I got back.
A similar event happened last week too when getting into the car having been sitting and misting up inside, again cleared this time after a few minutes. Last edited by Sussex_G20; 10-25-2019 at 11:03 AM.. |
10-25-2019, 09:16 AM | #3 |
19
Rep 80
Did have an issue a couple of weeks ago when it was absolutely howling it down and spray on the motorway when I had a similar notification.
Once the car had been shut down and restarted , the issue seemed to have rectified itself so I just put it down to the weather. |
10-25-2019, 11:53 AM | #4 | ||
240
Rep 534
I thought the car was having a reboot as it just suddenly started slowing down!? The weather was bad but I was in worse at other times without issues (although switched off the lane guidance as it kept enabling/disabling itself when it couldn't see the road markings). Fair enough, it was torrential rain. |
10-25-2019, 03:35 PM | #5 |
22
Rep 62
Mines still on order, but most forward radar systems will switch themselves off in the type of rain we've been having the last few days. My stelvio did it, as did the c class and the qashqai I'm currently in.
10-25-2019, 05:10 PM | #6 |
27
Rep 165
As said here, my Qashqai told me on Monday that it was not working, this was because of the severe rain
10-27-2019, 09:53 AM | #9 |
48
Rep 170
So it happened today as well. Difference - it is sunny, not a single cloud, and dry.
So went to check the front radar, and saw this: Could it be that the bottom part of the platew with arval's info is actually causing this? |
10-27-2019, 10:33 AM | #10 | |
442
Rep 423
I think there is a big chance this is exactly what is causing the problem. The whole plate is too low in my opinion. Even without sensor problems It just doesn't look good. Bottom of my plate is level with the red line. |
10-28-2019, 02:07 AM | #12 | ||
240
Rep 534
I think there is a big chance this is exactly what is causing the problem. The whole plate is too low in my opinion. Even without sensor problems It just doesn't look good. Bottom of my plate is level with the red line.[/QUOTE] Quote:
10-30-2019, 09:04 AM | #13 |
48
Rep 170
ok - here's the update
it was the licence plate fixed too low, indeed. it was actually done not by Sytner, but by Arval (initial fitting) at least I was told like that. new, smaller plate was fitted, and was placed slightly higher. Now everything works like a charm! |
10-30-2019, 09:12 AM | #14 |
Grumpy Old Git
443
Rep 923
Drives: BMW G20 330i RWD M Sport
Glad you got it fixed..... must have been a Friday job putting on that number plate.... silly mistake.
Retired:
F10 520D M Sport E60 520D SE Volvo S60 type R |
10-30-2019, 09:38 AM | #15 |
48
Rep 170
10-31-2019, 11:41 AM | #16 |
21
Rep 323
Been a while since I've been in these forums. Sold my F30 330D 2 years ago for a Golf R, contemplating going back to the 3er now.
Anyway, I had the radar on my F30, loved it. I had the same issues with it (rarely) like some of you in the rain or snow. For the price of the option it seems a little bit unreliable. In the golf, it comes as standard and I've never had issues with it. Now with self driving its probably capable of doing a lot more, but the one in my golf and my old f30 for active cruise control, its not great value for the 3er relative. Auto cruise control is a must have now for me.
330D M Sport Estoril Blue 19" + M Sport Brakes, Adaptive Suspension, HK Sound, HUD, Stop+Go, Vis Pack, New Pro Nav.
10-31-2019, 04:15 PM | #17 | |
240
Rep 534
The one on my Mondeo was a bit rubbish, really bad a tracking round bends (even small ones) and was constantly speeding up and then slowing down as it lost and then found the car in front. Fine on the motorway but that's it. For some reason the sensor was offset to one side at the front rather than located bang in the middle, maybe that was it... The G20 system is way better than both as it keeps track of multiple vehicles at once all around you and so if you pull out to get round something slower in front but there is something close in front in the new lane it doesn't speed up and you can just slot in behind without accelerating or braking. In the Mondeo (and I think the Golf) as soon as you indicate right it speeds up and "rams" you into the back of the vehicle in front forcing you to brake (or disengage before pulling out). Similarly in the G20 if you overtake and then indicate to slot back in behind something it will match the speed. Very clever. Having said that be careful of the lane guidance system, it can get itself in a pickle, especially through narrow road works where there are alternative lane markings still visible. I've had mine lurch from tracking one set to another a couple of times (ie. push me out of the actual lane) and have had to grab the wheel sharpish... |
