10-22-2019, 06:39 PM | #1 |
Rep 44
Hit curb, what's bent?
I was turning to park parallel against a curb and hit the curb while my wheel was turned full right towards the curb, going only a couple miles an hour. Nothing looked bent, but my alignment is off - the car pulls to the left and I have to hold the steering wheel about 10* right to keep going straight down the road.
I dropped the car off at BMW today and they were unable to find anything bent and was able to set the alignment, but barely within factory spec. What part did I most likely bend? I'm thinking either the control arm/tension strut (https://www.ecstuning.com/b-genuine-...t/31126855742/) or the tie rod end (https://www.getbmwparts.com/oem-part...ItMGwtbDQtZ2Fz). Last edited by lilfoot; 10-22-2019 at 06:45 PM.. |
10-22-2019, 06:54 PM | #2 |
4017
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
What did the "out of alignment" sheet look like when it was measured?
Possible things that got bent are: tension strut, wishbone (LCA), tie rod, and strut. I would imagine the wishbone and tie rod are more likely to get bent first. How did the tension strut bushing look?
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
10-22-2019, 06:58 PM | #3 | |
Rep 44
10-25-2019, 02:27 PM | #4 |
Rep 44
Alignment sheet attached. The car steers straight again but the steering wheel is still just a hair off to the right when going down the road.
I’m tempted to order the lower control arm and swap it just because I bet it’s the part that got tweaked. |
