Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions Rear lights
      10-22-2019, 04:04 PM   #1
Iworkfuels
Drives: 2020 M340i
Rear lights
Is anyone capable of stopping my brake light flash when my turn signal is on?
A6bullet337.00
      10-22-2019, 07:02 PM   #2
TTG
TTG's Avatar
Drives: M340
I have done some serious research on this and the conclusion is that if you have a US spec car, the wiring / hardware is completely different and basically it can not be just coded.
I hope I am wrong and I hope someone can prove me wrong so that I can order a set of Euro Spec tail lights with proper amber turn signals.
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
A6bullet337.00
      10-23-2019, 10:14 AM   #3
A6bullet
Germany
337
Drives: 2020 330i Msport
Subscribed.
I am tired of the US spec cars getting the bad end of all the lighting options. The euro spec lights look beautiful and are definitely safer on the road.
RSnic657.50
      10-23-2019, 11:06 AM   #4
TTG
TTG's Avatar
Drives: M340
Further, ROW spec lights will provide rear fog light capability as well.
I don't think US spec lights have rear fogs built in which as least in the past we could get activated bec they were physically there, that is no more. What a bummer!
      10-23-2019, 03:18 PM   #5
Iworkfuels
Drives: 2020 M340i
I have the euro lights installed and I don't think the wiring is different. I am in the military stationed in the UK (which requires the amber rear turn signal for registration) and as soon as the new lights were installed, my brake light only illuminated the brake light. The turn signal is now the only odd thing out. I have it in a shop that has done the coding for a 2019 X5, but the G20 doesn't allow them to open the folders for the lights.
      10-23-2019, 03:20 PM   #6
Iworkfuels
Drives: 2020 M340i
I got the lights in and the EU switch and the car says it isn't available. Making me think it may just be a programming/coding issue. The rear fogs are next to the reverse light on the EU tails lights, and I haven't looked at my US lights to see if they are in there.
      10-23-2019, 03:32 PM   #7
TTG
TTG's Avatar
Drives: M340
I know exactly what you mean. I have the EU switch as well and get the same message.
The lights will plug in and function like yours do but I believe the modules just wont separate the braking function. Research on the X3 forums as there are few discussions over there as well as the G30 forums. I am not aware of anyone successfully activating the rear fogs or the Euro turn signals on US spec GX platforms.
If your shop gets them to work, there is hope for sure. Try to get the coding details for the rest of us if you don't mind.
      10-23-2019, 03:43 PM   #8
Iworkfuels
Drives: 2020 M340i
I will definitely share. I am just in a hurried situation as I can't register or drive it in the UK and the Italian government (bought through BMW Military Sales there) will come for a 32% "import fee" if I don't register it in the UK. I have contacted BMW HQ and they don't recommend the mod so they won't help me. Therefore, I may be forced to sell the car if I can't get this fixed.
      10-24-2019, 11:16 AM   #9
TTG
TTG's Avatar
Drives: M340
My recommendation is to reach out to all the coders on the forums to see if they can figure it out. We have some serious experts around.
This should not call for selling your car. Also, back in the day US State Department and military folks were exempt from local regulations for stuff like this......that must of changed since my time back in the day.
330iToy71.00
      10-24-2019, 12:27 PM   #10
Iworkfuels
Drives: 2020 M340i
Unfortunately, the SOFA basically says we have to follow host nation laws. There isn't a way around it. I am hoping to find someone who can figure this out. The place that has my car seems to think Tokenmaster's program can do it. But he is MIA even though we followed his instructions.
      10-24-2019, 02:55 PM   #11
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
I tried to mess around with the coding with Bimmercode on a 2020 M340i but a lot of modules, all except the headunit and alarm, was not recognized.
So it going to take some time before the coders and software develops that's compatible with the new ECUs in the G series.
Even if the US-spec tails is different than the Euro/ROW, you can repin the harness to match each appropriate light. Coding is needed though to move around the mapping output.
Euro vs US - spec taillights:
      11-01-2019, 08:05 AM   #12
A6bullet
Germany
337
Hey any updates on this issue with you? I know SOFAs are different for each country but I've never heard of anyone having to this particular modification. Its usually like retrofitting rear fogs or something simpler.
      11-01-2019, 08:26 AM   #13
Iworkfuels
Drives: 2020 M340i
Unfortunately I haven't made any progress. The place that has my car at the moment said it is possible, just technology needs to catch up. They have reached out to TM, but still no response. I called BMW's customer support since I told the salesman that I was coming to the UK before I put money down, but they have been of no help. I asked them on Wednesday to either help me or buy the car back.
I am hoping some coders will see this and be able to assist further because in the UK you register your car the same way you would if you were a local regardless of the nationality or military status.
      11-01-2019, 09:17 AM   #14
A6bullet
Germany
337
Man, I hear you. Ill do some digging around the people I know over here and maybe they've already solved this issue. The US needs to catch up to the rest of the world, its a real bummer.
BMW military sales after support sucks in a really bad way. Seems like thy're only interested in selling the car, once you have it good luck getting any type of help.
Hopefully you get some good news!
      11-01-2019, 12:58 PM   #15
Iworkfuels
Drives: 2020 M340i
I agree that the US needs to catch up with the rest of the world, I wish BMW did what the rest of the German brands do with their US spec tail lights.
I agree BMW military sales is the worst when it comes to after sales. Once I paid for the car in full, It took nearly a month to travel a 2 hour drive because of "paperwork." This is my first and possibly last BMW due to the way I have been treated through this process. To make matters worse, any dealership could probably fix the issue in a matter of minutes.
I appreciate you checking it out for me, I can at least say the support is there from the community, just not the company.
      11-29-2019, 03:34 PM   #16
Fast400
Fast400's Avatar
Germany
682
Drives: iX M60
2014 BMW  [0.00]
Any word? Did they get it sorted?
      11-29-2019, 03:42 PM   #17
Iworkfuels
Drives: 2020 M340i
No they haven't. Just got launcher pro and are working on downloading the pad files. Never used the software before so here's hoping.
      12-01-2019, 12:56 PM   #18
Fast400
Fast400's Avatar
Germany
682
Drives: iX M60
2014 BMW  [0.00]
If I'm not mistaking, I think someone mentioned the need for re-pinning the plug in addition to coding
      12-02-2019, 12:44 AM   #19
Iworkfuels
Drives: 2020 M340i
Is that just for the fog lights or all of the rears?
      12-11-2019, 08:13 PM   #20
cheapengineer
Drives: 2022 330e
Hey new here as I am considering the M340i as my next car. I also hate how the US tail lights work.
Anyway if BMWs work like vw/audi I see no reason why it would need rewiring because only the brake portion lights up when applying the brakes. This means that turn signals can be operated individually and are not wired with the brakes. Pretty sure only reprogramming is needed to make them function like row lights.
For rear fogs however I think you would need to run an extra wire that goes from the right connection on the electronics module directly to the tail light. You could check the number of connections on the harness of the inner tail light housing (1 reverse, 1 parking, 1 fog).
      12-13-2019, 11:07 AM   #21
cheapengineer
Drives: 2022 330e
Originally Posted by Poochie View Post
So wiring from one the two LED main brake light would of had to be re-pinned there and then repurposed as the turn signal but since that lower turn signal on US-spec vehicles as Emergency Brake Lights, it's doesn't need to be re-pinned, just repurpose to be the turn signal as the ROW.
Just so that people don’t get confused the lower strip you are showing is also the turn signal on the US lights. The difference is that the brake lights (the two small strips above the parking lights) also light up when using the turn signals.
As for physical differences, the Euro spec only has one small trip for the brakes and the lower strip is amber instead of red.
      12-13-2019, 03:41 PM   #22
TTG
TTG's Avatar
Drives: M340
Oh damn, you're right, the lower LED strip also flashes, I can't believe I never noticed it before.
So yes, no re-pinning, you just need to repurpose the small strip to function only as a turn signal as the ROW.
Do you know if the "rear fog light" LED cluster exist in US-spec vehicles?
Rear fog lights are right by the back up lights, so they are there but will need to be activated via coding.
I think, getting the turn signals to work properly will take some serious coding which no one quite figured out.
Appreciate 2
Poochie9104.50
g20
