Bimmerpost
4 Series
Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin G20 gas tank 15.6 gallons or 13 gallons ??
      10-15-2019, 04:52 AM   #1
Mb73288
31
Drives: 2019 bmw 330i xdrive
Why bmwusa.com says the 330i xdrive has a gas tank size of 15.6 gallons but my 2019 330i xdrive only seems to have 13 gallon gas tank. Is there 2 different gas tank options or is my car just not filling all the way full.
      10-21-2019, 08:20 PM   #2
vivatus
Drives: M340i
Can't imagine the M340i is too different but mine is definitely around 15.6 gallons.
Mb7328831.00
      10-21-2019, 08:23 PM   #3
bimmer456
2961
Drives: 340i
You're not completely empty when you fill up, 13 gallons sounds about right if you're pretty empty when you fill up.
Mb7328831.00
      10-21-2019, 09:51 PM   #4
Mb73288
31
Thanks guys im guessing there was some fuel left in tank when i filled up .but i just thought it was weird bc my connected drive app also never goes above 13 gals when i fill up the car.
      11-08-2019, 10:58 PM   #5
F30BimmerChris
F30BimmerChris's Avatar
Drives: 2013 F30 BMW 328i
All cars do this, when you go fill up it's always going to be 1 or 2 gallons below the actual gas tank size. Keep in mind that there is fuel in the system, like the fuel lines, etc.
The Range the car shows, even if it's at 0 doesn't really mean it's dry, there will always still be about a gallon left.
I've seen my range go to 0 several times in a previous generation 3 Series that has a 15.8 gallon tank and the maximum amount of fuel I've ever been able to pump is 14.6 gallons.
Hope this helps.
      11-22-2019, 01:36 PM   #6
VipinLJ
Petrolhead
VipinLJ's Avatar
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
I had the low fuel level light come on when I had around 65 miles remaining. Average mileage on my car right now is 22.2mpg. So roughly 3 gallons left in the tank?
I filled up 13.2 gallons worth of petrol for a full tank after that. So yes. I’d say it’s around 15.6 gallons or so.
      08-17-2022, 05:09 PM   #7
IsleOfMs
84
Drives: M340i
Hope this helps.
This has always been true for all my other cars but not my 2020 M340i.
My owner's manual says I have a 15.6 gallon tank and when my computer says I have 4 miles left, it held 15.5 gallons. I know it's bad to go really close to empty but based on every other car I've ever had, when it read "0 miles to empty" I expected 1 to 1.5 gallons of reserve.
This car literally tells you when it's empty. It's very hard to see "50 miles to go" and actually go fill up bc I'm conditioned to believe there's an extra 30 miles of range beyond that 50.
g20
