How hard to spin engine?
10-10-2019, 11:17 AM | #1 |
80
Rep 414
Drives: CL55 AMG
Hey guys how hard is it to make the engine spin with a wrench? And what way would you have to turn it? I tried with a wrench that’s not that long and I can’t make it spin it’s pretty tough.
10-10-2019, 11:23 AM | #2 |
Clean is the new cool, keep it that way.
808
Rep 1,685
With a short wrench it will be tough. With a breaker bar not so much. Strength varies though.
2011 335i, FBO, N55+ Turbo, full E85, S55 intercooler, etc.
2015 X5 35i Xdrive |
10-10-2019, 11:43 AM | #3 |
80
Rep 414
Drives: CL55 AMG
10-10-2019, 12:10 PM | #4 |
17314
Rep 18,737
Is the transmission in neutral? Pull the plugs out. Engine spins clockwise. If you break the crankshaft bolt loose, you will loose camshaft timing, so be careful.
10-10-2019, 12:27 PM | #5 |
80
Rep 414
Drives: CL55 AMG
Yeah trans in neutral and yeah I thought of pulling plugs, with plugs in it would be hard to spin the engine. I saw the engine turn on the other day but now it just makes a click sound when I hit the stop start button
10-10-2019, 01:01 PM | #6 |
3058
Rep 3,910
Sounds like your starter is dead. I doubt it's anything to do with how easy (or not) it is to spin your engine...there is always a lot of drag in an engine - pistons/rings, cams, valves, chains, balance shafts (if yours has them), PS pump, alternator, ac, etc etc, as well as compression.
10-10-2019, 01:27 PM | #7 | |
17314
Rep 18,737
