10-09-2019, 05:32 PM | #1 |
19
Rep 78
Brake Fluid Reservoir
Is there a thread anywhere here that details how to get to the brake fluid reservoir and check brake fluid level?
I have it figured out for my 430; getting the right section of the black plastic cover removed, but it's not as apparent with our X1. Also, anyone have any idea what the cylindrical areas circled are for? F48 Engine Bay Last edited by gkamieneski; 10-09-2019 at 05:42 PM.. |
10-10-2019, 12:10 AM | #2 |
137
Rep 310
Unsure what those circled parts are.
Here's a link to the newtis.info brake bleeding procedure: https://www.newtis.info/tisv2/a/en/f...nes/1VnYucD7qF The brake fluid reservoir is under the cowl panel between engine bay and firewall. You should see it once you remove the large plastic piece. |
wcs2229170.50 |
10-10-2019, 10:49 PM | #3 |
60
Rep 173
https://www.newtis.info/tisv2/a/en/f...der/1VnYDdracD
Gives you a better look as to the location of the brake fluid reservoir (3rd & 4th pic down). Viewed from the front of the car, it's located just to the right of the battery and tucked back a bit . |
10-11-2019, 10:36 AM | #6 |
19
Rep 78
Thanks. Noticed it was 5 fasteners, whereas only 3 for my 430. Amazing how many differences in the engine compartment when both vehicles were assembled in Regensburg.
10-12-2019, 12:07 PM | #7 |
19
Rep 78
10-15-2019, 11:16 PM | #9 |
60
Rep 173
Still pretty sure that BMW hasn't changed the location. Have you attempted to remove that cover that's right there at the battery terminal post? IIRC, when I installed my Battery Tender charging harness, I removed two bolts and a blind plastic rivet. If you only want to see the level of the fluid, just look thru the bonnet (hood) hinge from the drivers side to see the level (full; half way, right at the molding seam).
10-15-2019, 11:18 PM | #10 |
60
Rep 173
10-16-2019, 08:06 AM | #11 | |
19
Rep 78
10-16-2019, 05:17 PM | #12 |
19
Rep 78
O.K. I can see enough of the reservoir, I guess, from the side near the hood hinge. Or at least I can tell the fluid is up to the "seam" which I understand is between Min and Max.
Beats having to remove some fasteners to just check a fluid level. Thanks. Question: Why do the manufacturers always make the brake fluid reservoirs of opaque white plastic when a clear plastic vessel would allow seeing the fluid level so much better? |
04-22-2020, 07:59 PM | #13 |
19
Rep 78
A little update on my quest to check the brake fluid level on my 2019 X1.
Turns out, I really cannot see the level from the side through the hood hinge area. These reservoirs are made of such an opaque white plastic that even aiming a concentrated flashlight beam does not show me where the fluid level is at. I did find this page, https://www.newtis.info/tisv2/a/en/f48-x1-xdrive28i-sav/repair-manuals/00-maintenance-general-note/00-00-maintenance/1VnYtKH5Do that did apply to my 2019 X1. Unfortunately, you have to remove several plastic expansion rivets to remove the rear cowling. Hope this information will help someone else looking to access their brake fluid reservoir. |
04-23-2020, 01:44 AM | #14 |
75
Rep 383
If the fluid level was low I think you would get a “Brake Level Warning Light”
Everthing goes to Entropy in this Age.
04-23-2020, 07:32 AM | #15 | |
19
Rep 78
There's a dearth of information on the procedure for this model. |
09-06-2020, 06:30 PM | #16 |
17
Rep 59
The answer to OP's second question, about the round holes in the engine bay, is that they are the supports for the hood adjusters, which I guess BMW stopped including in the later models. Part # 51767183752
